Go with whats installed..
What's installed is usually correct if it is original. Service manuals are notoriously full of errors and I am not beating up on Sansui. Howard W. Sams comes to mind. But one has to go with what one has.
I would go with the original. And for that matter, very low value resistors are often still good. It seems that the large value carbon resistors are the ones that drift very often.
Finally came back to this project.
On the driver board replaced the electrolytics, fuse resistors and trim pots. Turns out that one of the trim pots was bad. It read 1k and will not adjust when turning. This was probably the cause of my 1st issue when trying to adjust bias.
Hopefully the rest doesn't take me a year
Those two center trimmers are going to be real fun to adjust.
