super98lsc
Well-Known Member
Ok decided to start on unit #1 which is cosmetically really nice. Probably a 9 out of a 10. No scratches on the face or dials or back panel, zero rust, clean inside and out other than honest dust from years of use. Unit # 2 works flawlessly but is a train wreck cosmetically and is missing the power switch all of the internal shielding panels and the top cover. If anyone has a cover or power switch they want to part with PM me please. :yes: More on that one later.
1. Unit fires up fine lights up DBT then idles dimly lit.
2. Clean audio out of the left channel only. Some small crackles can be heard out of the right side if you crank into the volume a bit. No blown fuses etc. Likely the fusistors.
Starting the rebuild tonight. (likely to use upgrades provided by Leestereo!)
Pictures will be all the teardowns so if anyone ever "needs to know where a wire went" or how the cable routing was done from the factory etc.
