Thanks. I set the overhang with the factory gauge and took a reading from stylus tip to base of headshell with a digital caliper. I then mounted the Denon cartridge and duplicated the tip to base distance. Almost a perfect match to a Technics overhang gauge. Thanks Fever
I just made a template with the 16.1 distance on it and put it over the spindle and allign the cart to it. Works fine.
Assuming I was correct aligning the black line with the tab of the headshell in the first pic. I took a caliper reading of 52.35mm where the W Is located In this diagram below. Washer was removed for measurement. Fever
Same here.I just measured 16.1mm from the center of the spindle to the stylus.
