ThaiBerra
Member
Help with AU-999 partslist verification
At last I think that I have completed a correct shopping list for the recap and
restoration of my "new" AU-999. The amplifier is not yet delivered to me so I
have done this list from the schematic diagram, the parts list and information
from countless threads here at AK.
I know that the list is quite long but I would appreciate very much if as many
Sansui "experts" as possible could take time to check the list to see if it's ok.
I want to make it as correct as possible so it could be used and to good help
in future AU-999 projects.
All components are planned to be ordered from Mouser except the Nichicon
Super Through capacitors (Parts ConneXion).
Components for the Bass EQ Control Mod & Pre-amp Mod are included.
The SP Protector Block (Crowbar) F-1334 will be removed.
Have I missed anything?
I'm trying to get the list as complete as possible.
Looking forward to your inputs/comments
Bernt
Main Filter Caps
C002 & C003 Electrolytic Capacitor 4700µF 50V (40mm*80mm)
Nichicon Super Through 6800µF 63V (40mm*100mm)
Outputs
TR819-TR822 Silicon Transistor 2SC898 863-MJ21194G MJ21194G
F-1228 Head Amp. Block
C603 Electrolytic Capacitor 10µF 25V 647-UKL1V100MDDANA 10µF 35V
C604 Electrolytic Capacitor 10µF 25V 647-UKL1V100MDDANA 10µF 35V
C607 Electrolytic Capacitor 47µF 10V 647-UKL1C470KEDANA 47µF 16V
C608 Electrolytic Capacitor 47µF 10V 647-UKL1C470KEDANA 47µF 16V
C609 Electrolytic Capacitor 33µF 6.3V 647-UKL1C330KDDANA 33µF 16V
C610 Electrolytic Capacitor 33µF 6.3V 647-UKL1C330KDDANA 33µF 16V
C621 Electrolytic Capacitor 33µF 50V 647-UKL1J330KPD 33µF 63V
TR601 Silicon Transistor XA495 522-ZTX795A ZTX795A
TR602 Silicon Transistor XA495 522-ZTX795A ZTX795A
TR603 Silicon Transistor 2SC458 512-KSC1845FTA KSC1845FT
TR604 Silicon Transistor 2SC458 512-KSC1845FTA KSC1845FT
TR605 Silicon Transistor XA495 522-ZTX795A ZTX795A
TR606 Silicon Transistor XA495 522-ZTX795A ZTX795A
F-1209 Tone Control Block *2
C719 Electrolytic Capacitor 10µF 25V 647-UKL1V100MDDANA 10µF 35V
C723 Electrolytic Capacitor 47µF 10V 647-UKL1C470KEDANA 47µF 16V
C729 Electrolytic Capacitor 33µF 25V 647-UKL1V330KEDANATD 33µF 35V
C733 Electrolytic Capacitor 47µF 10V 647-UKL1C470KEDANA 47µF 16V
C735 Electrolytic Capacitor 10µF 25V 647-UKL1V100MDDANA 10µF 35V
TR705 Silicon Transistor XA495 522-ZTX795A ZTX795A
TR707 Silicon Transistor XA495 522-ZTX795A ZTX795A
TR709 Silicon Transistor XA495 522-ZTX795A ZTX795A
F-1159 Driver Block *2
VR801 Output Balance Adjustor 5kΩ 81-PV37P502C01B00 5KΩ Murata 12turn
VR803 Bias Adjustor 1kΩ 81-PV37P102C01B00 1KΩ Murata 12turn
C807 Electrolytic Capacitor 47µF 10V 647-UES1C470MPM 47µF 16V Bipolar
C809 Electrolytic Capacitor 100µF 25V 647-UKL1V101MPDANA 100µF 35V
TR801 Silicon Transistor XA495 522-ZTX795A ZTX795A
TR803 Silicon Transistor XA495 522-ZTX795A ZTX795A
TR805 Silicon Transistor 8002-1 522-ZTX694B ZTX694B
TR807 Silicon Transistor 8002-1 522-ZTX694B ZTX694B
TR809 Silicon Transistor 2SC281 Any replacement for this?
TR811 Silicon Transistor 2SC875 512-KSC2690AYS KSC2690AYS
TR813 Silicon Transistor 2SA532 512-KSA1220AYS KSA1220AYS
D801 Diode SM-150-01 512-1N4148 1N4148
D803 Diode SM-150-01 512-1N4148 1N4148
F-1208 Filter Block
C717 Electrolytic Capacitor 10µF 25V 647-UKL1V100MDDANA 10µF 35V
C718 Electrolytic Capacitor 10µF 25V 647-UKL1V100MDDANA 10µF 35V
TR701 Silicon Transistor XA495 522-ZTX795A ZTX795A
TR702 Silicon Transistor XA495 522-ZTX795A ZTX795A
TR703 Silicon Transistor XA495 522-ZTX795A ZTX795A
TR704 Silicon Transistor XA495 522-ZTX795A ZTX795A
F-1230 Ripple Filter Block
C006 Electrolytic Capacitor 220µF 50V 647-UPW1J221MPD 220µF 63V
C007 Electrolytic Capacitor 220µF 50V 647-UPW1J221MPD 220µF 63V
C008 Electrolytic Capacitor 100µF 50V 647-UPW1J101MPD 100µF 63V
C009 Electrolytic Capacitor 100µF 50V 647-UPW1J101MPD 100µF 63V
C010 Electrolytic Capacitor 220µF 50V 647-UPW1J221MPD 220µF 63V
D002 Silicon Diode 10DC-1R 512-1N4004 (2*1N4004)
TR001 Silicon Transistor 2SD223 512-KSC5603DTU
F-1277 Minus Ripple Filter Block
C814 Electrolytic Capacitor 100µF 50V ±10% 647-UPW1J101MPD 100µF 63V
C816 Electrolytic Capacitor 4.7µF 50V ±10% 647-UPW1J4R7MDD 4.7µF 63V
TR824 Silicon Transistor 2SA532 512-KSA1220AYS KSA1220AYS
F-1231 Plus Ripple Filter Block
C813 Electrolytic Capacitor 100µF 50V ±10% 647-UPW1J101MPD 100µF 63V
C815 Electrolytic Capacitor 4.7µF 50V ±10% 647-UPW1J4R7MDD 4.7µF 63V
TR823 Silicon Transistor 2SC875 512-KSC2690AYS KSC2690AYS
AU-999 Bass EQ Control Mod
Metal film resistor 1MΩ ¼W 71-CCF071M00JKE36 *2
Metal film resistor 2.2kΩ ¼W 71-CCF072K20JKE36 *2
AU-999 Pre-amp Mod
Metal film resistor 3.3kΩ ¼W 71-CCF073K30JKE36 *2
Metal film resistor 1kΩ ¼W 71-CCF071K00JKE36 *2
Metal film resistor 100Ω ¼W 71-CCF07100RJKE36 *2
Bernt
Main Filter Caps
Outputs
F-1208 Filter Block
AU-999 Pre-amp Mod
