ghazzer
Senior Member
Are bias circuits between left & right channels linked in any way?
I have been working on a G-6700 for quite a while, and have observed cases when I was adjusting one channel down and the other would rise. Admittedly this happened in situations when the initial bias in each channel was higher than desired.
I have been measuring bias as the voltage drop across the two 0.47Ω(5) emitter resistors in each channel and the desired bias current is 10 mA, so the ultimate desired voltage is 9.7mv. I am still working on a DBT with a 60W bulb and I realize that the bias increases as the size of the DBT bulb is increased, or I take it off the DBT. So, please take these numbers with a grain of salt.
Starting with the 60W DBT I measures B+ at 34V and Right bias at 36.8. Then I changed the DBT to 75W and B+ went up to 37V and Right bias rose to 53mv, so I swapped back to the 60W DBT. I try to always measure the rail voltages because P/S voltages will change as the line (mains) voltage changes.
For this case I started with rail voltages of ±34.5V, Left bias= 28.9mv and Right bias = 42.4mv.
Adjusted Right bias (VR04) down to 10.0mv and Left bias rose to 43mv.
Adjusted Left bias (VR03) down to 25.4mv and Right bias rose to 12.4mv.
Found a balance at 13.4mv each, but it was not a null.
Adjusted Left bias down to 10.0mv and Right bias rose to 14.2mv.
Adjusted Right bias down to 10.0mv and Left bias rose to 10.2mv.
Adjusted Right bias down to a null at 9.2mv.
Adjusted Left bias down to 4.0mv and Right null rose to 9.6mv.
I did not want to adjust the left any lower.
Now I am hoping that some one can explain how the bias in one channel can affect the bias in the other.
