anderslober
Yikes...not again!
Hello Forum.......this unit is part of my plunder from the US of A. While I wait for some parts to arrive for some other units, I will start the redo on this 'famous' amp.
It seems in pretty good condition. The PS has been recapped by someone else. Good quality caps have been used. Everything else seems completely original. I changed the voltage to 240v operation. I then dbt'ed the unit....bright then dim......relays clicked. A good sign. Hopefully the speedy outputs are ok!
Black flag caps will go. The usual supect tr's/diodes will also go.
On top of the EQ board there is a connector.....what does this connector connect to? I couldn't find any loose connectors inside the unit.......
I will post pics soon..........
