Thank you for the response, I did try the way it says in the manual, by turning the bias pots counter clockwise, putting the probes from my meter one on Q13 and the other on Q14 emitters. My problem is that when I turn the bias pots up I get no mV reading (nothing but zeros) until I turn up the volume control with signal applied, then I get a unstable reading that changes with the volume control. When I turn the vol. up mV go up, when turned down mV go down. Any Ideas ?
Thanks, JD
Thanks for the reply, Just to making sure which ones would they be?
Thanks, JD
KR26 a dual .33 Ω 5watt ?
Yes, I did check those, seemed Ok. They didn't appear open.
Thanks, JD
Yes, I went from center post to each end of the resistor.
Should be able to measure them in circuit.Would it be better to check those resistors out of circuit?
JD
