U-Turn Turntable - Has anyone got one yet?
Orbit Plus TT- continued...Finally, some music!
Well, I FINALLY got to listen to some music! I listened to one LP in the morning before the family all arrived for Thanksgiving, then a little bit more after they left at night. As I write this, I've been listening for a couple of hours this morning.
First, I cued up an album that I didn't even remember, “A Winter's Solstice” on the Windham Hill label.
At first, it sounded very constricted and dull. No life at all. I hoped that it was the low-end cartridge and went about my business. It sounded a little better by the end of the first side but I thought it was just me getting used to the inferior sound. Then it happened. Somewhere around the middle of the second side, it started sounding REALLY good. By the end of side 2, after only about 40 minutes of playing time, it was so good that I couldn't concentrate on anything else. So, I played side 2 again. Sublime! I assume that this was due to the cartridge “breaking in”. Also, this was the first time I had used the phono stage in this preamp. For whatever reason, the weak link here was just starting to hit its stride.
The family was due to to start showing up any time, so I moved on the the next test- Joe Perry's “Once a Rocker, Always a Rocker”.
Why would I listen to this as a test, you might ask? Simple- it's the worst case of a warped LP that I have out of the hundreds of LPs I own. The first two tracks are the worst. My Revox, with its ultra-short tonearm, displayed visible and audible distress on these tracks. On the Orbit, nothing. No drama, no horrible distortion, it just PLAYED.
Next, I put on a rather obscure album from the band New England, “Walking Wild”.
It has some drum tracks with decent impact as well as some ethereal-sounding keyboards. Other than that, I also have it on digital so that I could compare the two. Really, not bad. Obviously, digital has the quieter background but, overall, the two were quite comparable. So far, so good
Next, I moved on to the Doobie Brothers “The Captain and Me” album of which I have on a Nautilus Recordings pressing.
This isn't the greatest recording in spite of the superior label but I really like the music. It was just as I remembered it when I used to play it on the Revox- a fairly black background with acceptable sonics (compared to the Warner Bros. Release).
Lastly, I cued up Michael Hedges “Breakfast in the Fields” also on the Windham Hill label.
By now I was having a problem with cleaning after the demise of my Nitty Gritty. I just could not get the dust and dirt off the records. The near “black” background was lost as I was trying to ignore the snap, crackle and pop. By the end of side 1, this listening session was over. Even still, the close-miked guitar had real bite and realism. The cartridge is still getting better. As an entry-level TT, this won't hold anyone's system back. I would like to see how far it can go before it does.
The Orbit TT was used with this associated equipment in my family room:
Audiosource Pre One preamp with MM/MC phono input
AudioSource Amp One power amp
Paradigm Micro speakers
Klipsch subwoofer
This isn't my main system but I thought that it would be closer to a system that most people would use this TT with. I'll try it at some point with my better gear. First, I need to address the RCM problem. Stay tuned...
Hopefully the Nitty Gritty can be salvaged. Sounds like the glue on the hoses dried out causing the leak or the fluid tank has a crack. Remove the bottom cover let it warm up and dry out. Usually a simple DIY fix or if needed new parts available from Nitty Gritty. At this rate it could be July 2014 before we get a review on AK.
In the other thread someone mentioned their table being on the way and their intent to compare with their MMF 2.2.
Sorry for my impatience, report indicates that after a short cartridge break in period the U-Turn is sounding pretty good. Key to better results will be with clean records and making sure the stylus is clean. Get the Nitty Gritty repaired/going, use a stylus brush and a carbon fiber brush to remove any light dust etc from the record before playing and the U-Turn will have a good fighting chance to show its true capabilities. I'v repaired a couple Nitty Gritty RCMs and it wasn't difficult to do.
Pretty good review so far...and happy to hear its s good tracker with decent reproduction. Mine is designated as a gift to my son and future daughter in law so this should work out. Of course I will do the break in ;)
Thanks for making this so comprehensive.
Orbit Plus TT- continued...epilogue
Sorry about my battles with recalcitrant equipment. Well, that's the real world for ya.
Largely, I satisfied my own curiosity about the U-Turn Audio Orbit TT. I admit that I was a bit skeptical about its quality and performance. The long wait didn't help. I didn't expect it to be as good as it was. I really expected to hear a bit of motor noise. I expected a little trouble with tracking some warped LPs. I even expected the Ortofon 5e cartridge to be far worse than what I was used to. I expected the machine to be more resonant.
Actually, what I found is that the TT makes music. That's all I ever wanted. U-Turn delivered on its promise. I wish I had the gear to measure wow & flutter, etc. but I don't. I can only give you my listening impressions. So far, those have been only positive.:yes:
I'll be looking at some upgrades as time goes by. Definitely a cartridge upgrade, maybe a speed controller. I don't feel that I'd be throwing money away here. After all, if you can't spend money on a hobby then what good is it?:D
I wish this fledgling company well and hope that they made a little money on this venture. I can't wait to see their NEXT model!:thmbsp:
unionist we couldn't of asked for a better review of the U-Turn Orbit turntable, great job. As you said U-Turn delivered on its promise of an low priced simple turntable that will make enjoyable music without damaging records.
Yes, excellent review. It seems like U-Turn had a clear goal in mind and managed to attain it. Well done on both parts.
One thing I don't understand is why they don;t explain the differences in cartridges between the Basic model and the Plus -- the only place you can even find a description of why the Plus costs more than the Basic is buried in the Take It For a Spin paragraph. They say the Plus has the acrylic platter and a better cartridge. Do you suppose they are so worried about sourcing cartridges at this low price point (and therefore cartridges may end up changing from month to month), they are better off not even mentioning what they are fitting to the tonearms? Or am I missing something that is explained on the site and I just haven't seen it?
Sure is great to see someone sourcing materials and components from US suppliers and talking about that with pride!
Yes, what exactly differentiates the Plus aside from a glass platter and $100?
Never mind, saw the Accessories page. Just the platter.
If reviews like Unionista's keep coming in I send a Plus and a base model in mine and my girlfriends future....
Sent from my Nexus 5 using Tapatalk
Barncats my sentiments exactly that finally we are seeing an affordable quality USA made turntable. Materials and parts subcontracted from USA suppliers and assembled by US workers contributing to badly needed jobs. Hopefully the trend will continue with products like those that were from Dynaco, amps/preamps etc instead of the low budget AV receivers from overseas.
I just looked at their website, it appears that an AT95E is the cartridge included in the "Plus":
Orbit Plus Turntable Blue
279.00
The Orbit Plus Turntable with an acrylic platter and an Audio Technica AT95E cartridge.
DELIVERY: January 2014.
Yes indeed, and *affordable* is the operative term here, without sacrificing quality (at least as we seem to be hearing from unionista's first impressions.)
In 1967 I paid $78 for my AR-XA. I think I must have bought a Shure M55E for a one-cent add-on price. I just went to the dollar calculator and that $78 would be $544 today. Which makes the Orbit a stunningly good buy.
As someone said earlier in the thread, it is looking as if finally, we have something we can recommend to friends who want to get into vinyl and do not want to fuss with vintage -- basically just want plug-and-play -- and every purchase is contributing to local jobs in the bargain. Everyone wins.
The Tone Audio issue with the Orbit review is now posted. Nice, positive thoughts on it.
Thanks. Great review. Added some much needed context. Interesting about the silver-plated tonearm wire. I bet that contributes to that 'swiftness and agility'.
I wonder how that unnamed magazine that told U-turn they wouldn't review 'vaporware' is feeling now...
Orbit Plus TT
I just read the Tone Audio piece. I'm glad that we both had similar perceptions on the TT's performance. I saw that the reviewer picked up a little wow & flutter on piano notes. I didn't have anything on hand to base a comparison but he might have been correct on that point. I did also want to try increasing the tracking force but, seeing that it was spot-on, I decided on an out-of-the-box review.
I have some brand-new and never-played vinyl along with their digital counterparts. That comparison should prove illuminating but first, I have to repair my RCM! That's it for now!:D
