moodydan
I love the punk rock.
I'm working on a QRX-5500. Initially it would start up, sound was good, but after about 15 minutes of playing it would kick into protection mode and not come out. So, I replaced the caps on the protection board (except for the bipolar caps, because I didn't have any on hand; also, the 220uf/75v and 100uf/75v I replaced with 160v capacitors because that's what I had on hand - the uf values did match, though).
Now, the protection relay clicks upon being powered on, but immediately trips. I removed the output board, and the protection relay clicks and is fine - at least, for the 20 minutes or so that I had it turned on, it did not click again.
I tried setting the DC offset and bias, but it didn't get me anywhere. Where bias is supposed to be 25+1mv, I'm getting about 33V, and the variable resistors don't change anything for me at all. Bad trim pots, maybe? Suggestions are appreciated!
