You're right. When they are rehabbed, and the tuner and MPX is aligned, it's a great receiver. My 1st tube receiver is a sansui 1000a I got back in '09. I still havne't tweaked the tuner yet, but the mpx plays very well. The output circuit is very similar to my FISHER 800-C's. It's got more of a "IN YOUR FACE" attitude, vs. the laid back attitude of the FISHER. I use the Sansui for Rock, classic Rock, Metal, anything faster and newer than 1960. Anything orchestral, chamber music, big band, or music before that the FISHER Shine's. It might be just voicing in how the engineers designed the circuits, but to me the SANSUI is more of a Brawler type of fighter, and the FISHER is more a Judo type fighter. (Sounds crazy I know, but that's how I see them.)
10ohm resistors on the cathode to ground (replace the ground with the resistor) pin 5 to ground on the outputs will allow you to measure the tube draw of each tube and if the fuse blows, will turn off the tube, and save the output transformer. Use a metal film 1/4w resistor. If your's is a 2 or 4 pot unit, you can turn the bias down to between 30 and 34ma. With mine that is between 70-80% of max dissipation of the output tubes. They'll run cooler, and still put out good sound. This is a more accurate way of biasing the tubes than going by the bias voltage.
If it's a single or dual pot unit you can convert it to a 4 pot unit(IBAM or Individual bias Adjustment board), or a BAL/BIAS board by Dave Gillespie. Go over to the FISHER Forum and search IBAM, or BAL BIAS Adjustment for 800-C. They work in the 1000A without modification, and give you a lot more control over the bias than the original circuits.
