vigman
SUBSCRIBER
1st , Snow,,, Thank you... this is a beauty...armor plated packing too!
Not alot of time today.... But the score so far...
Power supply's are are online..
Audio final bricks and pre drivers pulled..
Unit will not come out of protect ... I assume since there are so many missing bits..now.
Preamp section works almost.. ( had to pick off a bit upstream ) .
Meters work ( in input mode ) 1/2 the meter backlights are out.
After realizing the balance pot was not on the shaft correctly (30 degree offset) 1) Final brick 100%
3) Shorted transistors in the other
1) Smoked 2507 board...no detail on damage on that....
AND SOUNDS AMAZING!!!!
