sebalele
Member
Ciao sansui lover ,
Some months ago I've done a partal recapping on my sansui 8500;
Everythingh were working fine .recapping has improved sound ,has open his wings letteraly...
Some days ago I've received an elettronic parts box to repair and upgrade others hifi stuff.
I begin to replace elettrolytic bipolar that i've not in hand on the first job .they were only 6-7 not a heavy work.
When tested no sound at all! The relais doesn 't switch . I 've wasted lot of time searching for a problem on 2019 board .this acts like protection &power supply regulation .
After having jump the relais ,putting a power resistor (20 ohm) in serie with speaker I've discovering that fault was on left driver board .
From this channel come out a loud scream for a second than protection goes on.
Switching 2029 board from L to R ,scream follow the board .
With multimeter seeem everything in order ,bjt are ok ,diode ok,...just a differente impedance in the tr801-3 differential input .
Out of the board these couple of 2sa726 have the right junction...searching on net some tech said that these old transistor (they were already old in 70') leaking with the age .
So ...look for a replacement. ,some said ksc1845 & KSA992 are the right replacement ;I 've placed an order ...poland.1,2weeks delivery .
In the meantime I've read about bc559 560 rep...I've tried with the corret leg exchange.but no result ....not at all...relais switch ,hear a scream for ms,than amp goes to protection .
I like to know if someone else has really replaced sa726 with bc 550...
I'm afraid these bc550 are high hfe so goes to saturation..
Title said 8500&9500 just because use same driver board (somedays ago I open same thread in wrong section.
Many thank
Gabriele
Many thank
Gabriele
