Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > General Audio Discussion
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 03-07-2007, 01:36 PM
nickrobotron's Avatar
nickrobotron nickrobotron is offline
that's a good cup of jaja
Can someone show me how to hook up an FM antenna? Please!
Right now I just have a piece of speaker wire stuck to the back of my receiver and it helped reception, but it still sucks. I don't listen to FM, that's why I'm just now asking. I would like to start listening to more of it though. So can someone take a snap shot of the back of their receiver or just carefully explain it to me? Thanks!
__________________
Pro-Ject Debut Carbon, NAD C 516BEE, Rega Brio-R, Monitor Audio Silver RX-1
  #2
Old 03-07-2007, 01:52 PM
Holst's Avatar
Holst Holst is offline
<-Me and Mahler
It's not my tuner, I found the pic online but, look for those screws. You have a common and a choice of 75 or 300 ohm.
If you are settled on speaker wire (not the best pick) hook one end to the common, the other to 300 Ohm.
I dipole anttenna is a better pick, same hook up. It's that "T" shaped wire thing you can by at Home Depota/Fleet Farm/Radio Shack/and so on.
the 75 ohm is your using coax for your antenna wire.
Best bet, a rooftop antenna, let us know when your ready to make that move.
__________________
Main: McIntosh MC2125/C27, Ohm Walsh 300's, AMC CD8b, Luxman K-373, Marantz 2110, Sony ST-3950SD, Phillips N4504, SOTA Moonbeam/V15II/JICO-SAS
Mancave: Yaqin MC100B w' KT120's MS11B, Ohm Walsh F's, Luxman D-373, Grant Fidelity DAC09, Realistic TM-8D, Sparta GT-12
  #3
Old 03-07-2007, 01:56 PM
Markw's Avatar
Markw Markw is offline
Banned
So, waddaya got back there?
An "F" connector, like they use on cable TV? That's for a 75 ohm lead. You simply screw the antenna lead into this.
Or perhaps a couple of screw terminals? These are for 300 ohm "flat" lead, which is rarely used anymore. You would connect one side of the lead to one terminal and the other side to the other.
You can buy cheap adapters to convert either one to the other depending on your needs.
But, sometimes punting* works just as well when one doesn't have a proper antenna.
But, before flogging yourself with that lone wire, you should at least try one of those $3.00, 300 omm "T" antennas that RatShack sells. If you're in a decent area it should help but don't be surprised if you need more of an antenna to get some decent performance.
Poke around this site. It can be very helpful for FM issues. http://www.radio-locator.com/
*this would mean just taking any wire and connecting it to any antenna terminal and, moving it around, and hoping for the best. All I have on my CSW Model 88 is a single wire sticking into the middle of the "F" connector.
  #4
Old 03-07-2007, 02:05 PM
electronjohn's Avatar
electronjohn electronjohn is offline
Plug it in & see!!
An older unit will likely have 3 terminals...one marked ground or "gnd", and two marked "ant" or 300 ohm. (with the upside-down U symbol for ohm, possibly?) One of the 300 ohm teminals may also be marked 75 ohm, with a line or some sort of marking "linking" it to the ground terminal. The ordinary cheap "T" FM antenna would connect to the 2 terminals marked 300 ohm. Your speaker wire might make do til you can scrounge or buy a "T" antenna. (they're cheap. Just take a 6 foot length or so and separate one end of it so the two ends are 30-36" apart when spread out to the shape of a "T". Separate the opposite end a few inches, strip the ends and attach to the 300 ohm terminals. Try orienting the "T" in different directions for best signal. Should coaxial cable be involved...you can either connect the center conductor to the terminal marked "75 ohm" and the shield to the ground terminal. Most amplified FM antennas have a coaxial cable with an "F" type connnector (same as cable TV) at the end. Some receivers have a "F" jack on the back for FM, so it's just plug 'n play. Otherwise, to eliminate the need to cut the connector off, strip the cable, etc., just get a cheap 75 to 300 ohm matching transformer...screw the cable to its jack and connect the twinlead that comes out of the transformer to the 300 ohm terminals. Matching transformers are 2-2 1/2" long and about 1/2" in diameter with an "F" screw-type jack on one end and a short lenght of twinlead coming out the other. Cheap and easy to find at Lowe's, Home Depot...heck, even Radio Shack might still stock them! Plus, there's a good chance they'll carry a pre-made "T" type antenna for a couple bucks that'll perform a little better than a homebrew job made from speaker wire. If it's an outdoor antenna you desire, if an FM-specific antenna isn't readily available, an inexpensive outdoor TV antenna will do the job. They can also be mounted in the attic or the top of a closet if outdoor mounting isn't feasible. Twinlead feedline can be used, or 75 ohm coax (RG-59U) with matching transformers at each end.
Hope I was helpful!!
  #5
Old 03-07-2007, 02:06 PM
Plug it in & see!!
As usual, I'm typing while everyone else is posting!! LOL
Audiokarma
  #6
Old 03-07-2007, 02:46 PM
Holst's Avatar
<-Me and Mahler
Quote:
__________________
  #7
Old 03-07-2007, 11:16 PM
Paul C's Avatar
Paul C Paul C is offline
AK Member
On the two terminals on the left... they are labeled 300 ohms. This is for twin lead, regular old fashioned twinlead TV antenna wire.
The 2nd and 3rd terminals from the left are labeled 75 ohm and Ground. This is for coax. The middle lead of the coax goes to the 2nd terminal from the left, and the coax shield goes to the 3rd terminal, which is chassis ground.
AM loop antennas, and that type is the only practical type for AM reception, connect to ground the AM, which is the terminal on the far right of that antenna terminal group.
Your exact connections may be positioned differently, but marked the same.
Some receivers have F-connectors, threadded connectors like on cable TV, which is 75 ohm.
If your receiver does not have connections for 75 ohm, but you have cable coming in from the antenna, then connect a balun aka transformer to the end of the cable. This is a small cylindrical device with the threaded F-connector on one end, and two 300 ohm leads on the other, usually with spade lugs. Connect the spade lugs to the 300 ohm terminals on your receiver or tuner, and screw your incoming cable to the other end of the transformer.
__________________
Avatar photo taken Dec of 1968. Heathkit Compact Stereo. On the turntable is Best of the Beach Boys (either Vol. 1 or Vol. 2).
  #8
Old 08-09-2013, 04:25 PM
iplagolf's Avatar
iplagolf iplagolf is offline
<- Aren't I handsome
I'm following this thread with interest. I hope no one thinks this is a hijack, I believe this is along the same lines as the poster. This is what I have. Home made dipole FM antenna mounted 40 feet above the ground. It's made with speaker wire wrapped around a 1" dia. 10' long plastic (PVC) conduit. I soldered a 75 to 300 ohm transformer to the speaker wire. Insulated it and connected to RG-6 cable and ran it inside the house. At my receiver I again used a 75 to 300 ohm transformer to bring the connection back to two wires with forked connectors and used the two screws on the back of the tuner to connect the antenna up. I get lots of stations except one at 104.1 out of Evansville, IN less than 30 miles away. I get it on a boom box, my truck, etc. I get several stations above 104.1. The question is, am I harming my reception by having two transformers in line? I looked on line for an F connector with two wires only. None found. I'm going to try a Radio Shack Cat. no. 278-201 chassis mount coaxial socket to try to fashion a cable to two wire conversion. Any thoughts on this? If this post is out of line here I apologize and will remove it to another place. Fritz
__________________
Too much stuff...
  #9
Old 08-09-2013, 04:54 PM
JoeESP9's Avatar
JoeESP9 JoeESP9 is offline
ESL's & tubes since 83
Their will be some insertion loss from any transformer.
Have you tried this? It screws right to the end of any F connector equipped RG type cable.
Radio Shack Part Number 15-1230, $6.29
The price is rather high as they can be had for $2 to $3 elsewhere.
__________________
  #10
Old 08-10-2013, 05:41 PM
Doug G.'s Avatar
Doug G. Doug G. is offline
AK Member
You've been following this thread for over 6 years?
Hehe. Just kidding.
I would just try the dipole (the "T" shaped antenna) hooked to the 300 ohm terminals on your receiver. It doesn't sound like you actually have a dipole with wire just wrapped around a plastic tube.
Doug
Audiokarma
  #11
Old 08-10-2013, 05:52 PM
Gun Doc Gun Doc is offline
AK Member
I've had good luck with "rabbit ears" as well. Not fancy, but easier to move around than the "T" if the T isn't pointing the right way when tacked to the wall you might have to use.
  #12
Old 08-10-2013, 06:19 PM
musichal's Avatar
musichal musichal is offline
AK Member
Interesting, nickrobotron still hangs out here, so I'm wondering how often he finds himself listening to FM these days? I do, sometimes, but MOG sharply curtailed the already relatively small amount of radio via the home system.
If he does still use FM occasionally, what did you do about an antenna, nick?
__________________
Klipsch Forte - Emotiva mini-X a-100 - Lexicon DC-1 - Schiit Modi
How sweet the moonlight sleeps upon this bank!
Here will we sit, and let the sounds of music
Creep into our ears: soft stillness and the night
Become the touches of sweet harmony.
  #13
Old 08-10-2013, 07:40 PM
getright99's Avatar
getright99 getright99 is offline
least likely to succeed
Great thread
__________________
Technics SA-939
JVC QL-F4
JVC XL-V211
Realistic SCT-40
Realistic Minimus 7's
  #14
Old 08-11-2013, 09:03 PM
larryderouin's Avatar
larryderouin larryderouin is offline
AK Member
Quote:
Radio Shack sells 300oHm antenna cable still. It's either 50 or 100ft for like $18.00. Why not make a proper 300oHm T Dipole and connect it up in place of the speaker wire, balun,cable, balun affair you have now.
Some antenna's (especially the "T" Dipole) are directional. I think you'll find if you rotate that affair you have, you'll probably pick up that one station you can't get on it now.
6ft cross piece. Connect the ends together. In the middle, cut one side, but not all the way thru, strip back and connect (solder) the leads to the down wire. Then attach two U lugs and connect to your stereo.
I find I get better reception with 300oHm twinlead than with cable to my VHF/UHF/FM antenna on the roof.
__________________
FISHER Consoles; 51 Coronet, 59 510/610 (both chas,) and 560, 63 Exec VIII, 64 E-49-W, 65 E490-P,'65 F590-W.
FISHER Rec/Tun/amp; TA-600, 101-R, MPX-100, 250-T, 550-T, 500-TX(2), 700-T, 800-C, TX-100
PIONEER SX-424, 434, 737, 939, 790
Sansui 1000A, 2000, 2000a, 2000x
  #15
Old 08-12-2013, 03:19 PM
toxcrusadr's Avatar
toxcrusadr toxcrusadr is offline
I Didn't See Nothin
I like old TV rabbit ears. Easy to find at garage sales. The newer TVs came with rabbit ears with just a small plastic post meant to stick into a hole on the molded plastic rear of the set, if you were going to use it. I make a wood block with a hole in it to set it in.
__________________
Spend your resources and talents doing good.
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Organ Donor Parts
Vintage Home Audio
Parts Connexion
Wargos Electronics
Take Five Audio
Sonneteer
Audience AV
Sound Stage Direct
Simply Speakers
AudioClassics
Howard Products
AV Solutions
FM DX Antenna
Musical Paradise
Grant Fidelity
McIntosh Cabinets
Yesterday's Audio
BOI Audio Works
DeWick Repairs
Amplifiedparts
Politicalchat.org
RSL Speakers
Urban Antigue Radio
The Tube Store
Many Moons Audio
Audio Doctor
Videokarma.org
MCM Electronics
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
ęCopyright 2002-2014 AudioKarma.org, All rights reserved.
