catrafter
Marantz Specialist
A thread in another area of the forum reminded me that I had forgotten to post pictures of my phono preamp project.
When I moved my Technics SL-1200 into the surround setup in the living room, I found the built in phono stage of my Sony DA3200ES receiver to be lacking in dynamics and it had a bit of hum and noise as well. The Technics sounded fine on my Marantz 4300, and if I used my 2230 as a preamp that worked well too.
I did a little shopping on our favorite auction site and scored a phono preamp board from a Marantz 2250B.
On the phono board, I replaced the power supply filter cap (C413) with a new one of the same physical size, but with about twice the capacitance. The input coupling caps (C401-2) which were tanatalum types, were swapped for film caps of the same (1 uF) value. The board is made to accept either footprint. I used a 30 VDC wallwart adapter from Jameco for power. The adapter puts out about 38 Vdc with the preamp's light load, so I replaced the power supply feed resistor (R434) with a 1K Ohm 1/2 Watt and added a 30 volt 1 Watt zener diode across the power supply filter capacitor. This keeps the preamp operating at near the level of the original design, but with a little more safety margin for the electrolytic capacitors used (35 volts).
The sound I think is very good. The dynamics are back and the hum and noise are gone!
I'm still trying to figure out a way to put a blue face on it though!
Tom
Tom
