Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > General Audio Discussion
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 06-25-2008, 04:01 PM
Signal-Green Signal-Green is offline
AK Member
Speaker hum caused by my receiver
I'm a newbie to receiver maintainance.
I get a hum through any speakers I use only with this HK receiver ever since I bought it used. After 2 seconds on, the hum loudness drops to half strength and stays there; but its still loud. I've tried alot of configurations. Its there no matter what knobs I turn; and with nothing connected to it.
FYI - there are 3 fuse knobs on the back, and a GND screw.
Any simple things I can try? Thanks.
  #2
Old 06-25-2008, 04:28 PM
toxcrusadr's Avatar
toxcrusadr toxcrusadr is offline
I Didn't See Nothin
What's the model # and approx. age?
Does the volume of the hum change when you change the volume knob?
You might have failing filter capacitors in the power supply.
__________________
You let us enjoy what we have and we'll let you enjoy that big pile of whatever it is you have. - westend
  #3
Old 06-25-2008, 04:33 PM
westend's Avatar
westend westend is offline
Audiopile
You could try running a wire from the chassis ground screw to the faceplate screw on the receptacle it's plugged into. That might cause more hum or it might eliminate it. It's an easy thing to try. Another thing to try is looking inside the receiver and look for any oxidation on any of the chassis grounding points. Tighten down the transformer, also.
Besides these grounding issues, most hum problems are causd by a failing/failed capacitor and that is a little more work to nail down. Look for any bulging or leaking caps.
  #4
Old 06-25-2008, 06:53 PM
AK Member
Interesting you should ask. That was my next thread. But I just opened the receiver and found this printed inside: "APR2967. I assume thats a date. Model says "Two Hundred" on the front. On the bottom is says THK-21.
No(edit: Yes - on phono and phono mono, but not tape.)
It's my 1st time opening a receivr, so I don't know what a transformer looks like.
there's a little red and brown stuff on them.
  #5
Old 06-25-2008, 09:21 PM
cademan's Avatar
cademan cademan is offline
AK Member
If you don't know what a transformer looks like, it might not be a good idea to go poking around inside. If you want to learn, now there's a good idea.
Audiokarma
  #6
Old 06-25-2008, 10:15 PM
titanstats's Avatar
titanstats titanstats is offline
Go Habs Go!
Try flipping the plug over, seeing if the polarity change will help, if not, try using a different electrical outlet. Do you have your cable hooked up to it for FM? That can give a hum, as well as your computer, if it's hooked up. Sometimes it's the little things...
__________________
McIntosh C27, 2 x MC2125,
Altec Model 14, Technics SL-10,
Heathkit AJ-1510 FM tuner,
Altec LF-2 coffee table sub.
Koss ESP 9
  #7
Old 06-27-2008, 09:10 PM
AK Member
I'm tried all the above and still have the hum.
I was mistaken on one thing: The hum DOES increase in volume as I turn up volume - on phono and phono mono, but not tape.
  #8
Old 06-27-2008, 09:26 PM
westend's Avatar
Audiopile
Are you using a Turntable? What is the condition/type of interconnects you are using? Give us a little more infromation about your system
  #9
terra1's Avatar
terra1 terra1 is offline
AK Member
Does it get really hot to the touch?
  #10
Old 06-28-2008, 12:04 PM
x_25's Avatar
x_25 x_25 is offline
Big Vandies!! Mwahahah...
Try flipping the plug around. Even though the plug for the wall is non polarized, some times it can cause a hum if it is in backwards. As for the phono hum, if you have a Turn table hooked up do you have the ground wire for the turn table connected to the receiver?
__________________
Pre: Musical Fidelity A3cr
Amp: Musical Fidelity A3cr
Sources: Rega RP855, Phillips DVD 963SA, Squeezebox
DAC: Matrix Mini-i
Cart: Ortofon OM20
Speakers: Vandersteen 2Ci
Sub: JBL PSW-1000
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Analog Engineering Associates
Capacitor World
Okki Nokki
Hudson Valley Hi Fi
Vintage Home Audio
Organ Donor Parts
Parts Connexion
Wargos Electronics
Take Five Audio
Audience AV
Sound Stage Direct
Simply Speakers
Sonneteer
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
Audio Doctor
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
