Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > General Off Topic Forums
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 12-28-2008, 12:02 AM
markthefixer's Avatar
markthefixer markthefixer is offline
ESCAPED:armed & dangerous
sump / utility pump filled with what type oil?
Help!! (hey, coming from markthefixer?????? here's one for the books!!)
I repaired a submersible Simer 120v 1/6 h.p. utility / sump pump yesterday in anticipation of today's floods. The pump caught me by surprise and dumped it's entire fill of oil on the bench (no manual, too old?) and mopping the flood of oil up contaminated it badly, that which wasn't absorbed by the towel.
The submersible pump appears to be filled to the brim with oil for lubrication and cooling, as the water to be ejected flows up around the wall (aluminum no less) of the motor chamber under pressure, thus absorbing heat from the motor.
All I have to do is refill the thing with oil, close up the o-ringed fill hole (why didn't I drain it? good question... in retrospect) and start pumping away.
After a day of dedicated searching, I have NOT come up with a good answer as to what to use. It was too late on Friday night to call Simer to find out.
If it's too viscous at low temperatures, pumping 32 degree water will either stall or drag the motor badly.
It must be compatible with the varnish insulation on the motor coils ( I WAS considering using brake fluid - until I remembered how brake fluid will take off paint!!) as well as the rubber seals.
I thought of compressor and pressure washer pump oil, but rejected it because there was no indication of electrical compatibility of the additives they bragged about.
I also thought of Mineral oil, but that appears to be too thick compared to the saved and contaminated sample.
SO, has anyone successfully repaired an oil immersed sump pump motor and refilled it with NEW oil? It would have been SO much simpler if that darn fill plug hadn't been set up with a straight screwdriver blade anti-tamper "slot" that was REALLY frozen....
Any thoughts? I would like to pump out my backyard tomorrow...
By Monday, there's plenty of places that will be open for me to call, but by then, I'll probably have an ice-rink...
__________________
Nothing is ever completely fool proof, because fools are so ingenious.
  #2
Old 12-28-2008, 12:46 AM
SAE2922's Avatar
SAE2922 SAE2922 is offline
got sae?
Mark - Read this link and/or read it below. Maybe this can give you an idea of the viscosity and characteristic of your pump oil.
Good luck.
__________________________________________________ ____________
http://en.allexperts.com/q/Electric-...mp-motor-1.htm
Electric Motors - submersible pump motor
Expert: Will - 9/7/2007
Question
QUESTION: had to dis assemble a submersible pump to replace a float switch. did not realize that inside the sealed steel casing - the motor was "immersed" in oil. The oil leaked out.Have replaced the switch - is it simply a matter of reassembling the motor into the case and then filling with an appropriate oil? and if so how can I find out how much to use.
ANSWER: Noel, no nameplate? the correct way to do this is to drain the oil, save it, have it tested, and then match what came out.
This sounds industrial or commercial, I have not seen an oil cooled sub pump for everyday use.
I need more information.
Will
---------- FOLLOW-UP ----------
QUESTION: Hi Will - thanks for the response. ~The pump is made by the ABS company - model # MF 054 & its a light wastewater pump. It's used in septic tank to pump waster water upto a percolation area. Unfortunately all oil leaked away. Just wondering if it is possible to refill once I know the oil type or is it beyond repair. Can see the pump details at www.absgroup.com. regards Noel
Get the answer below
Sponsored Links
Submersible Pump
The Top Industrial Resource. Find Submersible Pumps Quickly.
Submersiblepumps.Industrial101.com
Central Vacuum Motors
Replace Your Central Vac Motor Lowest Prices Online - 800.322.2965
www.Thinkvacuums.com
Water Pumps In Stock
Water pumps, systems & accessories usually ship next business day
kingpumps.com
Dayton Electric Motors
Looking for Dayton Electric Motors? See Dayton Electric Motors.
GrovesIndustrial.com
Answer
Normally these pumps are filled with "turbine oil". ISO 68 or ISO 100. It is used in huge turbine bearing applications.
It can be bought in small quantities, but you will have to go to a bearing distributer or lubricant distributer.
I have no idea about this pump other than what it says on the website which obviously is available to anyone.
You might call them and ask if they have a seal kit that includes the oil.
But just because a pump had oil in it, does not make it beyond repair.
It may be a type that is not designed to be repaired, but many oil filled pumps are repairable, I would say the majority of oil filled pumps are repairable.
Will
__________________
SAE2922
SAE Akai Pioneer Rega JBL
  #3
Old 12-28-2008, 02:45 AM
SAE2922's Avatar
got sae?
MSDS sheets and info for turbine oils.
TURBINE OIL GST ISO 68
http://www.setonresourcecenter.com/m...c/wcd00cb4.htm
http://www.seversonoil.com/pdfs/Indu...urbine_Oil.pdf
TURBINE OIL GST ISO 100
http://www.burkeoil.com/pdf/ro1002.pdf
http://www.burkeoil.com/pdf/roturb1.pdf
For a price prospective, I googled-up a company that sells turbine oil ISO 68 in a bulk 55 gallon drum for $15 and change per gallon!!.
http://www.gopurepower.com/store/lis...cat=Industrial
Another site says to use ISO 30 turbine oil or synthetic SAE 5W30 motor oil as an alternative. Read here: http://www.libertypumps.com/faqs.asp
__________________
SAE2922
  #4
Old 12-28-2008, 03:48 AM
vegabass25's Avatar
vegabass25 vegabass25 is offline
Awesome AK member.
E-mail the company about what they use in their new pumps.
__________________
Cerwin-Vega! VE-12, VE-5M & 5C, VS-100. Paradigm DSP-3200v2 sub.
QSC RMX-1450 & GX-3, Denon AVR-688 as pre-amp
  #5
Old 12-28-2008, 09:50 AM
dokblues's Avatar
dokblues dokblues is offline
Just Glad to be HERE!
Turbine oil is exactly what you need, the only reason I know this is that my DAD`s company when I was a kid dealt in water wells and all water related equpiment for decades. Internally cooled sump pumps (ie) commercial types use turbine oil for cooling. And you can buy in small quantities or contact a local pump supplier.
__________________
Lightstar Amp, Lightstar Pre, Nad C 565 Bee, Pioneer PDR-555RW, Jolida JD9a modded, Teres TT, Benz Glider, AR ES-1 w/ Zyx R30-02
Maggies or AL-111`s for Beautiful Music : EV Aristocrats to Rock and Roll!
I may not have it all together: but together we have it all !!
Audiokarma
  #6
Old 12-28-2008, 10:12 AM
fotno's Avatar
fotno fotno is offline
AK Member
Try calling around to your local plumbing shops. Especially if you have an older Mom & Pop shop that's been around for a long time. Chances are they'll have some turbine oil that they'll gladly sell you a cup of. I've been out of the business for a while, but I always kept a gallon or two at my store.
  #7
Old 12-28-2008, 08:26 PM
Thanks for the replies and after balancing the various options, I'm probably going to go with the Liberty Pumps fill FAQ's suggestion, because of ease of acquisition (my ease, I don't get out much), Liberty's suggestion to use synthetic 5w30 (at least at first, If I run into drag problems, then I will make efforts to get the turbine oil).
The weather beat all my expectations, hours after the original post, before daybreak Sunday the temperature had dropped below freezing, and the only way that the water will leave the yard currently is if I chop it loose and carry it out. (or melt it)
So I have plenty of time now to get the stuff.
__________________
  #8
Old 12-28-2008, 09:15 PM
x_25's Avatar
x_25 x_25 is offline
Big Vandies!! Mwahahah...
Quote:
Flame thrower.
__________________
Pre: Musical Fidelity A3cr
Amp: Musical Fidelity A3cr
Sources: Rega RP855, Phillips DVD 963SA, Squeezebox
DAC: Matrix Mini-i
Cart: Ortofon OM20
Speakers: Vandersteen 2Ci
Sub: JBL PSW-1000
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Analog Engineering Associates
Capacitor World
Okki Nokki
Hudson Valley Hi Fi
Vintage Home Audio
Organ Donor Parts
Parts Connexion
Wargos Electronics
Take Five Audio
Audience AV
Sound Stage Direct
Simply Speakers
Sonneteer
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
Audio Doctor
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
