I place mine about 5-1/2 feet forward from the back wall. The wall is cement-and-soft-plaster over brick, with a "frame" of pillars in the corners and a similar extended "beam" across the top. In the recess thus created are shelves on the top part of it, and a large plasma screen in the middle. There are a variety of objects on the shelves, making the whole set up a bit of a diffractor/diffuser, except for the reflective plasma screen, but that is several inches forward from the wall, with an empty space behind it. Below the plasma screen are racks with audio gear on them, also diffractive. The whole creates a mix of reflection, diffraction and absorption. For whatever lucky reason, it sounds GREAT that way. I've toyed with removing some of the shelves and rearranging things, draping blankets over the plasma screen, pulling down the projector screen (which drops in front of the shelves and TV screen), etc... but nothing noticeably improves the way it is, so I just leave it that way.
For esthetic reasons, I don't have bass traps in those corners, but it doesn't seem to matter. The room, while not very wide, is quite long (nearly 30 feet), so it handles bass (which is primarily limited by the longest dimension of the room) quite well.
There are effectively bass traps at the other end of the room, and various other "treatments" on the side walls of the room, but they don't look like it. I mounted carved wooden decorative panels over cloth-covered foam, so they look like artwork but are also functional as sonic treatments, but they are only to take a little edge off of a slightly lively room. I'm lucky to have side door openings at two major reflection points, so that is completely not an issue. The panels do the rest well; the room is not quite as dead as the costliest listening rooms I've been in, but I like it that way it is now.
I've seen another RS II owner put up large panels (about 4' x 7') several feet behind the speakers, when they were well out in a very large room. I don't remember what the panel material was (this was years ago, before I know enough to look), but I think they were simply a heavy cloth or felt material stretched on a frame(?). I believe they were a commercial product, bought through an audio dealer. This was about twenty years ago.
