Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Vintage Solid State
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 03-02-2010, 03:50 PM
tarior's Avatar
tarior tarior is offline
Dirty pool, old man?
Counterfeit 2SC2240
I was working on a customer's Marantz 140 today, and I wanted to replace the differntial input pair with some 2SC2240 transistors. I got to looking at what I had, and they were very different from each other.
The one on the right is a genuine Toshiba part from Mouser. The one on the left is an apparent fake, I'm not sure where it came from. It's pretty sad when the Chinese are counterfeiting 20 cent transistors.
__________________
System o' the Week: Marantz 2330, dbx DX-5 JBL 240ti.
  #2
Old 03-02-2010, 04:29 PM
Stuart Pedaso's Avatar
Stuart Pedaso Stuart Pedaso is offline
In too deep
Care to crack a couple open to compare dies?
__________________
Because it's my birthday, and I wants it!
  #3
Old 03-02-2010, 06:33 PM
tarior's Avatar
The dies appear to be similar sized, the pinout is NOT correct. It really pains me to wreck a perfectly good transistor, BTW.
Again, Toshiba part on the right, fake on the left. It's hard to tell without a magnifier, but the Toshiba is better quality. Note the discoloration about the die on the fake part.
__________________
  #4
Old 03-02-2010, 06:42 PM
glen65 glen65 is offline
Member
It appears that one is also a different pin out.
  #5
Old 03-02-2010, 07:23 PM
avionic's Avatar
avionic avionic is online now
Tech--Take a number..
Location: Fort Dodge, Iowa -Northern end of"tornado alley"
Quote:
Originally Posted by avionic View Post
Did the "so called" fake..work in the circuit. There is more than just Toshiba legitamately making these.And yes they can have different pin-outs.
http://www.datasheetarchive.com/data...A00422945.html
[QUOTE]Datasheet Home \ Datasheet Details
ST 2SC2240
TO-92 Plastic Package Weight approx. 0.19g
ST 2SC2240
NPN Silicon Epitaxial Planar Transistor for low noise audio amplifier applications. The transistor is subdivided into two groups, G and L according to its DC current gain On special request, these transistors can be manufactured in different pin configurations.
G S P FORM A IS AVAILABLE
SEMTECH ELECTRONICS LTD.
(Subsidiary of Semtech International Holdings Limited, a company listed on the Hong Kong Stock Exchange, Stock Code: 724)
Dated : 07 / 12 / 2002
ST 2SC2240
__________________
MOSFET's & YAMAHA ROCKS!!!
Big boys don't whine..
RET USAF 1978-1998
Audiokarma
  #6
Old 03-02-2010, 08:17 PM
ecluser ecluser is offline
AK Member
When we want a 2SC2240, we don't just want a transistor that work in a circuit, we want a low noise transistor.
Yes, the Chinese are counterfeiting 20 cent transistors.
I can send you a 2SC2240 that will not work. I bought six 2SC2240 from a local parts store (by chance they had only 6 in their stock!) and when I tried to match them, I couldn't measure their hFE, no matter what pin-out I tried.
I put them on my beloved curve tracer and it turns out that all of them were very bad PNPs !!!
Since this misadventure, I never buy transistors from this store (ÉlectroMike in Québec city).
In the picture on the first post, we can see that the left one is labeled c2240 Y. As I know, the hFE classification for the 2SC2240 is GR or BL. I didn't check all the datasheets for the 2SC2240 to see if some manufacturers use the Y classification...
  #7
Old 03-02-2010, 09:00 PM
avionic's Avatar
I get all my japanese tranny's at BDent haven't had a lick of problems. But I usuaully match up the suffix codes as well BL,GR. etc. BD has a very large selection. They also have a $15 min. order so I usually end up buying extra quantities..
http://www.bdent.com/
__________________
RET USAF 1978-1998
  #8
Old 03-02-2010, 09:04 PM
Member
PNP?
Wow..I guess they did screw them up.
Don't know if you would be interested but Fairchild make
a direct low noise replacement for these, KSC1845.
http://www.fairchildsemi.com/ds/KS/KSC1845.pdf
You could probably get some samples and give them a shot.
So far Ive had no problems with them myself.
  #9
avionic's Avatar
I only see GR and BL...
__________________
RET USAF 1978-1998
  #10
Old 03-02-2010, 09:09 PM
tarior's Avatar
Like ecluser said, I want the 2240 that Toshiba shows a datasheet for. If the pinout is different than Toshiba's datasheet, it's phony part as far as I'm concerned. Furthermore, what are the chances that these things are going to meet the proper noise, current, voltage and cutoff specs? I'm betting slim to none. They aren't identical or interchangeable, and I'm sure as heck not gonna stake my reputation on them.
As an example on the same topic, I keep Toshiba 2SC2383 on hand for a good all around replacement NPN. I've also bought Fairchild KSC2383, and you know what? Their spec sheet is practically identical to Toshiba's. Pinout, current, voltage, everything. In this case, these are basically the same transistor from two different mfrs.
A tech can do a hundred perfect jobs in row, but the one people will talk about is the one that turned to shit because of bad parts.
__________________
Audiokarma
  #11
Old 03-02-2010, 09:11 PM
tarior's Avatar
I actually ended up using KSC1845 in this case, but it only has half the current capacity of 2SC2240. I'm ordering new Toshiba 2SC2240s from Mouser in the morning.
__________________
  #12
Old 03-02-2010, 09:13 PM
dr*audio's Avatar
dr*audio dr*audio is offline
Fish fingers and custard!
I bought my 2SC2240's from MCM Electronics, and they have BL on them. The HFE measures around 380.
__________________
Warren
"Hugh: Don't touch me, I'm a doctor.
Judge Maxwell: Of what?
Hugh: Music.
Judge Maxwell: Can you fix a hi-fi?
Hugh: No, sir.
Judge Maxwell: Then shut up!"
  #13
Old 03-02-2010, 09:22 PM
avionic's Avatar
A noisy transistor I would not consider working... I was just stating that there are other companys legit or not unloading these on the market.And obviously there is junk out there.
__________________
RET USAF 1978-1998
  #14
Old 03-02-2010, 09:23 PM
tarior's Avatar
Quote:
Most likely the real deal, and you can tell by the lettering.
__________________
  #15
Old 03-02-2010, 09:24 PM
tarior's Avatar
With all due respect to you, in this case if it's not Toshiba, it's a junk fake as far as I'm concerned.
__________________
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Tone Arm Audio
Tuner Heaven
Classic Sound Repair
Take Five Audio
Acoustic Sciences Corporation
Audience AV
Cabledyne
BD Enterprise
BOI Audio Works
Howard Products
Amplifiedparts
Audio Art Cable
RSL Speakers
Siliconray
Salk Sound
Vinyl Magic Record Cleaner
Musical Paradise
Audio Salon
Urban Antigue Radio
Grant Fidelity
Many Moons Audio
Yesterday's Audio
McIntosh Cabinets
Simply Speakers
The Tube Store
DeWick Repairs
AudioClassics
Parts Connexion
Audio Doctor
Vintage Electronics Repair
MCM Electronics
Politicalchat.org
Herbies Audio Lab
Antique Radio Classifieds
Sound Stage Direct
Videokarma.org
FM DX Antenna
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
©Copyright 2002-2012 AudioKarma.org, All rights reserved.
