Audiokarma.org
Audiokarma Featured Sponsor
Audiokarma will be offline March 7th and 8th
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > DIY
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 12-10-2010, 04:30 PM
sxty8goats's Avatar
sxty8goats sxty8goats is offline
AK Member
Record Bin From single 4 x 8 Sheet of Plywood - Plans
Another member built one of these and I needed something to occupy my mind a bit. So I mocked one up in Solidworks to see what I could come up with. All in all it is a simple and nice looking bin.
It will hold between 500 and 600 records, currently modeled with 125 per section. (assuming 1/8" thick record sleeve.) so 500 is a conservative estimate. Top of record in the top bin will be @ 39" above the floor, a nice easy browsing height.
I have not built this yet, it is winter and I'm not sure I'd have the room. It was mainly done to see what I could get out of a sheet of plywood. Were I to build it I'd glue every seam and use nails / or screw to assemble. A solid glued seam will be strong as an ox once it drys. Below is Chimpkin's original post that inspired me to think on this, followed by my images and the cut drawing. If anyone builds from these plans, post a pic, I'd love to see it done in reality. Thanks to Chimpkin for the inspiration.
Quote:
Originally Posted by Chimpkin View Post
I mentioned before that I created an lp bin out of a single sheet of 4x8 premium ply.
Cut List: (Thumbnail)
Additional Images: See Post #8 in this thread for the first build
V2 Has Casters (easily added to V1) rated at 90 lbs per corner for a total of 360 lb capacity. 600 180g records weigh 240 lbs.
Caster: http://www.mcmaster.com/#catalog/116/1329/=agjps5
V2 also has a simpler cut list which results in deeper bins. I personally prefer the look of the shallower bin so I've posted both cut sheets.
V3:Vertical Grain Thanks go to Doc Zinger for this version.
Assembly and optional casters still apply. See other drawings for caster part number and assembly.
For those that want to have the grain running vertically and don't mine a few extra cuts.
The front shelf pannels are 1/16" shorter and the dividers are 1-3/4 inches shorter.
Other than that the over all dimensions have not changed.
You also must be a bit more careful to get the shelf cuts correct as they no longer
share the cut to get the same width.
Assembly Tips, Tips and Variations.
Links point to specific posts in this thread.
Staining Hard Woods from member : timie1
Draws added for storage from member x2turbo
Quote:
Originally Posted by Budabel View Post
I was so glad to find this thread. I built one from the original plans and then modified for more capacity. I managed to get 2 three level bins out of 3 sheets of plywood.
Yet another version. 3 sheets of 3/4" plywood to make 2 bins with 3 shelves per bin. Each should hold @ 600 records. I appoligize if the images are suddenly huge, photobucket no longer offers a thumbnail option as far as I can see. That was the main reason I used the service back when I used it.
Budabel came up with this version. You can find a photo of his finished racks and a PDF of all the below drawings here:
http://www.audiokarma.org/forums/sho...&postcount=282
  #2
Old 12-10-2010, 05:55 PM
dumptruck's Avatar
dumptruck dumptruck is offline
AK Member
Thanks for the write up, and good call starting a new thread.
Quote:
Originally Posted by dumptruck View Post
If I may suggest something, I think you should avoid having the upper shelf hanging on screws/glue. Maybe have a gap in the bottom divider, about 2/3 of the way back, and have a vertical support from shelf-to-shelf there? Looks like you could squeeze that out of the sheet. You could [also] do some triangle supports out of the remaining scraps for even more strength.
  #3
Old 12-10-2010, 10:10 PM
sxty8goats's Avatar
AK Member
Good call on the supports. You could easily cut a couple 1-1/2 thick strips and glue / screw those under the shelf to give it plenty of added support.
  #4
Old 12-10-2010, 11:19 PM
MikeCh's Avatar
MikeCh MikeCh is offline
AK Member
Quote:
Aka, cleats. Cool design that could be attainable by most with simple tools! Thanks for the idea as I need some more LP storage in a small closet and this really fits the bill.
Cheers,
Mike
  #5
Old 12-10-2010, 11:22 PM
ecandle's Avatar
ecandle ecandle is offline
AK Member
Bad ass, thanks
__________________
"Well there's one thing to know about this town
Not a person doesn't want me underground
Audiokarma
  #6
Old 12-10-2010, 11:35 PM
sxty8goats's Avatar
AK Member
Quote:
Cheers,
Mike
So that is what the carpenters call long ass gussets. I Typically work in metal and plastic. If you build it, please post pics. I'd love to see it outside of a computer model. I have to credit Chimpkin for the idea, I just was in the perfect position to be distracted from my metal and plastic for a few minutes and like the challenge of using one sheet of ply.
Quote:
Originally Posted by ecandle View Post
Bad ass, thanks
You are welcome.
  #7
Old 12-10-2010, 11:50 PM
bobva's Avatar
bobva bobva is offline
AK Member
Rack on
  #8
Old 01-04-2011, 12:47 AM
maxsaxophone's Avatar
maxsaxophone maxsaxophone is offline
AK Member
Thanks for the plans!
I found this thread yesterday and decided to give it a go. I followed the given specs for the most part, excluding the height of the sides, fronts, and dividers which were raised an inch each to reduce the number of cuts required and keep waste to a minimum. I think it turned out nice.
The unit is fastened together by 2" drywall screws. The plan was to fit it together and drill the screw holes, then disassemble it (for the back seat of my car) and move it from my parents' shop to my apartment, then reassemble it with glue added. The tacks we used to hold it together temporarily turned out to be more trouble to remove than expected, so the decision was made to keep it assembled, forego gluing the pieces together, and add more screws as well as support blocks (scraps used, waste eliminated!) under the shelves. My girlfriend volunteered her SUV, so transport is no longer an issue.
The edges are finished with 3/4" moulding, shaped somewhere between flat and half-round. It sits on 4 hard rubber feet and has a cable pass-through to allow for a lamp to be fixed to the underside of the top shelf. I'll stain it when the weather gets warmer.
If all goes well with this one, I'll have to con my stepdad, who made this one possible, into helping me do two more of these. One for the rest of my lp's and a modified unit for 45s, which i desperately need a solution for. I've got 9 expedit blocks packed tight as it stands, but my neck was not built sideways. Since I like to flip through covers with lots of extra room to browse, this unit will only hold about 60% of my records.
Thanks for the ideas and inspiration everyone,
Max
  #9
Old 01-04-2011, 01:15 AM
Numistrek09's Avatar
Numistrek09 Numistrek09 is offline
AK Member
Very nice. I'll save this one for the day when i have enough albums to fill it.
  #10
Old 01-04-2011, 01:21 AM
TebbieBear's Avatar
TebbieBear TebbieBear is offline
AK Member
Very nice looking cabinet. I would love to see what you have planned for the 45s as I also have a large number of the little buggers looking for a home.
Audiokarma
  #11
Old 01-04-2011, 01:27 AM
Scuzzer's Avatar
Scuzzer Scuzzer is offline
Fixed Bias
Sweet! That's pretty much exactly what I had planned for the listening room. Thanks for saving me the time and energy trying to actually plan the thing out.
  #12
Old 01-04-2011, 02:35 AM
AK Member
Quote:
Thanks a bunch,
I've only had a chance to draw up plans on graph paper, but I'll try to get them into the magic typewriter somehow. I plan on keeping the outside dimensions the same, but the 45s bin will have four shelves instead of two. The top one will be very similar to the lp version, the other three will look the same from the front, but will be drawers. Each shelf will have 2 dividers instead of one. The lp unit has 77" of space, the 45s unit will have about 220" of space. And while that number sounds huge, the need to be able to browse comfortably will reduce its efficiency a bit.
And if I actually follow through with the other cabinets and still am not satisfied, I think a matching audio center with a recessed TT and a mac mini or similar as an itunes player, with extra storage for record supplies to boot would be awesome.
Max
  #13
Old 01-04-2011, 02:54 AM
Slowhead's Avatar
Slowhead Slowhead is offline
AK Member
Thanks to all involved. I'll make one this Winter.
  #14
Old 01-04-2011, 03:12 AM
Arkay's Avatar
Arkay Arkay is offline
AK Member
Really nice design - Congratulations and thanks!
Unfortunately, it's something I'll have to file away for some future year. I live in a downtown apartment in one of the most expensive places on the planet, and have to think of space utilization in linear and cubic inches -literally! That design --as much as I'd love to be able to flip through records that way-- wastes way too many cubic inches of empty space for my circumstances. I'm stuck with sticking to Expedit-style storage... and even my Expedits have a couple of LPs slipped flat on top of the usual vertical ones, as well as a few stood flat across the fronts of each cubicle, which must be removed to see the spines of the others... Added up, that's like adding another cubicle or two to the whole unit. I also have more shelves on top, up to the ceiling. Even with a decent-sized (by local standards) apartment, I need to think and work that way, to keep everything in here and still have any decent "living space"... sigh...
__________________
People take different roads seeking fulfillment and happiness. Just because they're not on your road doesn't mean they've gotten lost.
-- Dalai Lama
  #15
Old 01-04-2011, 11:38 AM
sxty8goats's Avatar
AK Member
Max
Nice Max. I updated the cut list drawing to match your layout. Not only does it reduce the cuts needed, it allows for 4 cuts to be made at your local home depot so that you can put the parts in the back seat of a typical car. Nice. I didn't adjust any of the heights, couldn't quite see where you added an inch and I have ideas for the scrap anyway
Thumb, click for full size:
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Hudson Valley Hi Fi
Okki Nokki
Organ Donor Parts
Capacitor World
Parts Connexion
Vintage Home Audio
Take Five Audio
Wargos Electronics
Audience AV
Sonneteer
Simply Speakers
Sound Stage Direct
Howard Products
AudioClassics
FM DX Antenna
The Tube Store
Many Moons Audio
Musical Paradise
Yesterday's Audio
McIntosh Cabinets
DeWick Repairs
BOI Audio Works
Politicalchat.org
Amplifiedparts
Audio Doctor
RSL Speakers
Videokarma.org
MCM Electronics
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
ęCopyright 2002-2014 AudioKarma.org, All rights reserved.
