Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Solid State
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 04-07-2011, 01:34 PM
snobnob's Avatar
snobnob snobnob is offline
AK Member
Question Technics SU-G91
I'm new to hi-fi but I've been looking around goodwills and thrift stores recently and I found a Technics SU-G91 amp with a matching tuner, tape deck, and a pair of speakers I didn't recognize. It's listed at $125, is this a good deal? Also, as a newbie, what should I check for in the system?
  #2
Old 04-07-2011, 01:47 PM
Water's Avatar
Water Water is offline
AK Member
Unless the speakers are something worthwhile there is no way I'd pay $125. I think they are highly overpricing it. Nothing special about Technics gear. You can probably find something better on Craigslist or keep looking in thrifts.
__________________
Pioneer SX-750, SX-636 - Technics SL-Q2 - JVC XL-Z1050 - KLH Model Six
  #3
Old 04-07-2011, 01:49 PM
snobnob's Avatar
AK Member
Ok, thanks
  #4
Old 04-07-2011, 02:05 PM
GuyNoir's Avatar
GuyNoir GuyNoir is offline
Here at the Western World
Doesn't the "SU" denote a Class A amp? From what I've been able to gather, that's a 130 watt per channel amp.
__________________
J.River Media Center 20 → XONAR Essence ST S/PDIF → Emotiva XDA-2 | Sony TA-4650 | B&K ST-202 | A/D/S L810, AR93Q
  #5
Old 04-07-2011, 02:19 PM
deaner33's Avatar
deaner33 deaner33 is offline
Drew loves Thin Lizzy
Quote:
Maybe "New Class A" which ain't Class A. The amp should be decent though for that era.
__________________
Audiokarma
  #6
Old 04-07-2011, 04:54 PM
ev13wt's Avatar
ev13wt ev13wt is offline
AK Member
Quote:
Are you just being rude or plain ignorant? Totl Technics gear is really really nice stuff.
http://wegavision.pytalhost.com/tech...RS1800-001.jpg
Or google Se A1 SU A2... Both items, if you can find them, which I highly doubt, will be very expensive. Find me a A2 that works and I will buy you a new small car.
For about, 1500+ you can, if you find one, get a SE A3 MKII. It is to me the most beautiful amp ever produced.
I won't start about the turntable that was used in every radio station and club in the world.
__________________
Technics 1977: RS-1506 // 2x SE-9060 // SU-9070 // SH-9010 // SH-9020 // ST-9030 // SB-6000
Quote:
Originally Posted by pdm4606 View Post
I think the reason it hums is because it doesn't know the words.
  #7
Old 04-08-2011, 12:35 AM
ryuuoh's Avatar
ryuuoh ryuuoh is offline
FFXIV Summoner
I have a modest SU 8080, circa 1977. Cast aluminum faceplate, dual mono design. I bought one in in 1978 and sold it, a few years ago I bought a used one and repaired/recapped/refurbed it. I like it, it works well with my efficient speakers.
Bottom line, you need to do your research before judging Technics.
__________________
Akai AS-970 AA-5000S
Technics SU-8080, SL-1300, SL-20, SA-5
Luxman L-80V, L-430, T-240
Yamaha NS-670, NS-690II, NS690III, T-80, T-70, M-50, C-50, CD-S700
Denon TU-800, TU-1500RD
Bozak MB80
Sansui TU-717, 9090
sun tan, drink in hand
  #8
Old 04-08-2011, 03:23 AM
SVI2004A's Avatar
SVI2004A SVI2004A is offline
Synchro Bias
G91 is circa 1992 130W/ch with 20watt surround channels. Punchy amp, tho heatsink is too small. Make sure the cooling fan works if you crank it up (try this with no speakers connected) put spkr A on and then when the power meters head to the 10w bracket the fan oughta kick in. Other than that this amp doesnt have any bad points.
Oh ev13wt Im fortunate enough to have 2 SE-A3MK2 power amps I love em!
__________________
I remember when amps were amps and speakers were nervous!
  #9
Old 04-08-2011, 03:46 AM
ev13wt's Avatar
AK Member
Quote:
You don't need two, you should just send me one!
I know where I can get one, I'm still saving up for it. The "government" of the house will kill me if I just go out and spend 1500 on some amp, although she likes the looks of it too. I almost got an A5, but it doesn't really compare.
I admit, I am a bit envious.
__________________
  #10
Old 04-08-2011, 08:15 AM
Cogsinister's Avatar
Cogsinister Cogsinister is offline
AK Member
I also have a beautiful SU 8080 and the ultra rare SU-V909.(in Technics Black/Brown)....both wonderful amps....
__________________
I could rule the world.......if only i could get the parts.
Audiokarma
  #11
Old 05-01-2011, 12:24 AM
jz1276 jz1276 is offline
AK Member
I really need some help getting a remote to operate the SU-G91. I did some research and I found the RAK-SA902MH remote is supposed to operate the SU-G91 so I found one on ebay and bought it. Got it the other day but it doesnt work with it. I also have the ST-K55 tuner which it doesnt work with either. Here is what I am guessing...
on the back of the amp (SU-G91), there is an input for a cable that says "remote". Now, there is no sensor on the front of the unit for a remote, but there is one on the front of the tuner. I think the tuner I have isnt supposed to pair up with the amp that I have because there is no output for a remote cable on the back of it. I did however find a tuner on ebay (ST-K50) which does have the output for the remote cable. So I'm assuming this tuner I found on ebay is made to be paired up with the SU-G91 which will accept the remote command and send it to the amp through the remote cable. Before I go and replace the tuner I currently have with the one from ebay, I just wanted to make sure if my assumption is correct. Thanks!
Also, it looks like just a regular headphone jack cable (double sided of course) will send the remote signal. Is this also correct?
  #12
Old 05-01-2011, 01:35 PM
elduce's Avatar
elduce elduce is offline
AK Member
You are correct the ST-K50 will work with this.I have the SU-G70 amp and that's what came with it.These amps run hot so it's not a bad idea to reflow all the solder joints.
__________________
I can't pay attention 'cause I'm on that dust
  #13
Old 05-01-2011, 07:57 PM
AK Member
Quote:
So the ST K50 will work with BOTH the SU-G70 and the SU-G91?
Also, what type of cable do you use to sene the remote commands from the tuner to the amp?
  #14
Old 11-17-2011, 01:46 AM
AK Member
Two more ?'s about this amp. First, I'm assuming it came as a system with the tuner/cd player, etc. Does anyone know the model of the CD player it came with?
Second, I'm having some problems with the spkr. terminals. I have to keep repeatedly moving the wire bc the sound keeps cutting out. Anyone know how I can fix this? Thanks.
  #15
Old 11-17-2011, 06:32 AM
AK Member
The speaker terminals on Technics amps are notorious for being cheap and prone to breaking, i have a couple of quite high end Technics amps that are let down by those cheap " twist-on " speaker terminals.
If the set of terminals for speaker "A" is bad try using the set for speaker "B" and see if that helps.
In the long run replacing the terminals with decent heavy Banana plugs would be the best option to avoid trouble.
__________________
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Hudson Valley Hi Fi
Okki Nokki
Organ Donor Parts
Capacitor World
Parts Connexion
Vintage Home Audio
Take Five Audio
Wargos Electronics
Audience AV
Sonneteer
Simply Speakers
Sound Stage Direct
Howard Products
AudioClassics
FM DX Antenna
The Tube Store
Many Moons Audio
Musical Paradise
Yesterday's Audio
McIntosh Cabinets
DeWick Repairs
BOI Audio Works
Politicalchat.org
Amplifiedparts
Audio Doctor
RSL Speakers
Videokarma.org
MCM Electronics
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
