Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Speakers
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 11-18-2011, 08:38 AM
fpalbrecht's Avatar
fpalbrecht fpalbrecht is offline
AK Member
Smile Seeburg Dds-1
Found a set of dds-1's several weeks back. I've been looking for something with a bit more bottom end than my Snell E-III's. Since recapping my HK citation II, the Snells we're not able to do the job. So I stumbled across these. I replaced two woofers with stock utahs, replaced the diaphragms in the 806a's from Great plains and recapped the crossovers. So last night I finally get a test run. Wow, just what I was looking for. Sweet
Mids/highs, and enough bass to balance it out. Home run!
Thank you, Bill at Great Plains audio(the place for altec parts), Jeff at Soniccraft(for recomending caps for crossover), and this forum for more info than I could ever sort through.
Harmon Kardon citation II
Eico HF-85
Thorens TD-125mk2
SME 2009
Grado
  #2
Old 11-23-2011, 02:24 PM
fpalbrecht's Avatar
AK Member
update
Here's an update on what I've discovered about these speakers. When listening to most of my favorite recordings the balance between lows and highs is perfect. Some recordings there is to much high/treble. I only listen to vinyl on this system. It must be recording engineer hearing loss, I don't know? On good quality recordings, Wow these are really fun. I'm going to install a l-pad and see how that works. Will it color/effect the sound? Other than horn output.
Thanks Paul
  #3
Old 11-23-2011, 06:10 PM
theebadone's Avatar
theebadone theebadone is offline
AK Member
Making and installing the equalizer/attenuator Altec 30904 you will extend the highs and tame those 806s to tolerable levels. The schematic should be on this forum if you do a search.
  #4
Old 11-30-2011, 08:05 AM
fpalbrecht's Avatar
AK Member
Thanks, I find the search feature not very helpful. It usually gives me pages of stuff that doesnt seem related. But I will sift on. In the mean time I've installed l-pads. That helps a lot.
I also removed the plastic screen between the speaker and metal front. These are really fun!
  #5
Old 12-01-2011, 11:40 AM
fpalbrecht's Avatar
AK Member
I've found the Altec 30904. Now can someone link me to a schematic that incorporates a L-pad with it. Or would that be a no no?
Audiokarma
  #6
Old 12-02-2011, 09:28 AM
fpalbrecht's Avatar
AK Member
I would like to try the 30904. Does anyone know where a lpad should go? Now its after the crossover. If I install the 30904 would it(30904) go before or after lpad?
Thanks
  #7
Old 12-29-2011, 08:25 PM
fpalbrecht's Avatar
AK Member
I'm not sure if it's the diaphragms breaking in or new caps in the crossovers breaking in or a bit of both. But the dds-1's are sounding better/sweeter all of a sudden. I've noticed a big difference in the last few hours of listening. I'm thinking twice about the attenuator mod. Can anyone tell me how long diaphrams take to break-in? How about caps?
Thanks Paul
  #8
Old 12-29-2011, 10:48 PM
bryana's Avatar
bryana bryana is offline
You have my stapler!
http://www.audiokarma.org/forums/sho...=186835&page=2
post 22
Whaleman is quite helpful regarding the mods to the dds 1 crossover. I have not done any crossover mods to mine yet. Mine came single from two different owners. One had an L pad installed and one was stock. I will verify the L pad is quite neccessary. The efffieciency of the altec horn and driver is too much for the utah woofers. Way out of balance. I hope to mod mine this winter and possibly reveneer the cabinets. There is great potential in these to sound really nice. I think of them as a poor mans Altec model 19.
__________________
Yamaha CA-2010, Sony CDP-C85ES, , Denon DRM-800. , stacked Bozak b302a, thorens td 155mkII, sansui AU D-11, marantz 140, marantz 3300
Amrita Allegra towers.
  #9
Old 12-30-2011, 03:18 PM
DaWoofer's Avatar
DaWoofer DaWoofer is offline
AK Member
Those are some beautiful speakers for sure. I take it they came with Altec woofers. Seems as though their would be better choices for the woofer than Utah. But then again I don't know all the variables and have tried many variations myself. Deep bottom end is hard to come by but they looks as though they could blow your face off. Glad they are working for you and would love to hear a set some day. Nice stuff men!
  #10
Old 12-30-2011, 10:10 PM
fpalbrecht's Avatar
AK Member
They came with the Utah 15" woofers. And they will play plenty loud. I'm putting the attenuator on hold for the time being. I want things to break-in a bit more. A good recording on vinyl plus a tube preamp and amp these speakers sing. Santa gave me Clapton and Winwood live at Madison square gardens. Three 180g record set. It sounds fantastic!
Audiokarma
  #11
Old 12-31-2011, 10:40 AM
DaWoofer's Avatar
AK Member
Utah- I learned something new today. That is also dual 15s? What a combo!
  #12
Old 05-13-2012, 09:27 AM
fpalbrecht's Avatar
AK Member
DDS1 Update
Installed the Altec 30904 eq/attenuator yesterday. Listened about 4 hours last night. Should have done it a long time ago. But it takes time to know your speakers, and i wanted to know these before i made changes. The sound is much more balanced. Less in the middle, more bass. Better than just the L-pad. I didn't realize how much horn i was getting until now. It's not gone just balanced. It takes a little more power, not enough to matter though. Before, records with deep bass sounded good but others were missing the bottom end. Now a lot more sound good. I would highly recommend this mod for anyone with these speakers. I would recommend these speakers. A ton of bang for the buck!
Current system:
Thorens td-125 mk II imp.
Shure m97xe
Eico hf85, external power supply
Harmon kardon Cit. II
Seeburg dds1's
  #13
Old 05-21-2012, 08:54 AM
fpalbrecht's Avatar
AK Member
If anyone has a set of dds1's and has not installed the Altec 30904 eq/comp filter, do it. It transforms these speakers into something special. Just change the 6uf caps to 3uf. I'm rediscovering my record collection. What fun!
  #14
Old 05-21-2012, 09:05 AM
frperdurabo frperdurabo is offline
AK Member
__________________
JBL L1, Creek OBH 12 passive pre-amp, Heath AA-2500 (really an HK870), Musical Fidelity A3cr, Musical Fidelity V-Link II.
  #15
Old 05-21-2012, 09:08 AM
Ohighway's Avatar
Ohighway Ohighway is offline
AK Member
Quote:
Is this mod outlined in a thread here on AK or somewhere else on the web? Can you provide a link or links?
__________________
Speakers: Rotating between Allison Two, KEF 104/2, IMF-TLS80, and Fried C/2 - O/2. Currently playing: Fried C/2 - O/2
Amplification: Fisher 50a monoblocks , B&K Pro 10 Sonata preamp
Sources: Kenwood CD-206 cd changer, Denon DP-35f turntable with Grace F-9
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Analog Engineering Associates
Capacitor World
Okki Nokki
Hudson Valley Hi Fi
Vintage Home Audio
Organ Donor Parts
Parts Connexion
Wargos Electronics
Take Five Audio
Audience AV
Sound Stage Direct
Simply Speakers
Sonneteer
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
McIntosh Cabinets
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Audio Doctor
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
