Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Solid State
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 02-23-2012, 02:28 AM
Montycat's Avatar
Montycat Montycat is offline
½ º ° Ω μf β ÷ ≠ ∞ ≤ ≥ ±
Unhappy Picked up a Pioneer SX-450 with the dreaded power switch issue...
The cheap Pioneer SX-450 on the bench right now will probably have me cursing a bit. Pics will follow...
It's a good thing I only paid $15 for it because it appears, as is stated often in related threads, that the power switch disassembly and cleaning that it seems to need is a PITA. Oh well...I needed something to keep me out of trouble for the next few days.
I'll also be making some new ends for the case I think as it has some weird chocolate milk brown vinyl veneer on it. Fortunately the rest of the cosmetics are good and it's all there.
__________________
"Crisp and clear with every note as bright as the stars in the eyes of the girl you’re dancing with."
AFishNeedsAStereo
  #2
Old 02-23-2012, 03:07 AM
1973BuickGS's Avatar
1973BuickGS 1973BuickGS is offline
1993 Subaru Impreza 2.5L
Is it stuck on or off? My 750 is stuck on so I just put the plug on a switch. Yes, I am lazy, but it works. I'll probably fix it someday...
As for the vinyl, I redid my 450 (as well as my 750) in cherry vinyl from Dayton. They both came out nice. Here's the 450:
__________________
  #3
Old 02-23-2012, 09:29 AM
Montycat's Avatar
Nice job on your 450. I hope to get mine looking nearly as good.
However the switch is not stuck either on or off, it has the symptoms of significant contamination/corrosion that is talked about in multiple threads here, this being just one:
http://www.audiokarma.org/forums/sho...d.php?t=415741
It sort of turns on in that power seems to get to the tuner and the lights will flicker and sometimes even stabilize but no sound comes out. I'll dig in a bit deeper tonight. I didn't know what model or even series it was before going to get it, or I might have had something to look for. It does appear that the problem is fixable though.
__________________
AFishNeedsAStereo
  #4
Old 02-23-2012, 10:01 AM
quaddriver quaddriver is offline
120 What's per channel
I dunno if it was you I talked to, but I published a fix for the 4070 (et al) power switch on AK (with help from EW). Its easy to do and gets rid of the kludge.
__________________
QuadDriver
Pioneer Silver-face Collector
  #5
Old 02-23-2012, 10:30 AM
whitey's Avatar
whitey whitey is online now
No time for elitists....
Location: Pitt Meadows, British Columbia, The Dominion of Canada
I guess I owe you a coffee for sending this headache your way.... Good luck with the fix.
__________________
“If you tremble with indignation at every injustice, then you are a comrade of mine.”
Audiokarma
  #6
Old 02-23-2012, 11:19 AM
qsaudio qsaudio is offline
AK Member
The main problem is not breaking or messing up the tuner string, but if it has both sets of contacts, then swap them, it will be just like a brand new switch.
  #7
Old 02-23-2012, 01:52 PM
Quote:
Originally Posted by audiojones View Post
Wasn't me, but whenever I come across one of the many brands of receivers that use that same crappy Alps power switch I always clean what's left of the contacts and then install a RIB relay to handle the load. Done a bunch (most recently the 4070s and the 1515) and never had one fail or come back, and the RIBs have pre-wired leads so it's a good, fast and permanent solution. What's your fix?
lookit this thread: http://www.audiokarma.org/forums/sho...17&postcount=1
crap, wronggggg:
http://www.audiokarma.org/forums/att...8&d=1175137712
__________________
QuadDriver
  #8
Old 02-23-2012, 02:47 PM
Montycat's Avatar
Quote:
Originally Posted by quaddriver View Post
That looks better than some of the other threads I've seen on the Pioneer specific fix. I think that is the design I have but I'll look more closely tonight.
Thanks!
__________________
AFishNeedsAStereo
  #9
Old 05-21-2012, 11:18 AM
Adirondack Adirondack is offline
AK Member
That switch!
Hello Andrew & Audio Jones,
I have an SX-450 with that switch problem. I hate to say it but it's true misery loves company. I'm actually not the only one with this weird problem!
Flickers on power up, then works fine. I tried first to open the grey box about a 1/4" and spray with deoxit, helped a little. Then I opened the grey box all
the way (hoping & praying I didn't break that string) I cleaned the contacts
as much as possible (given the cramped quarters) with emery paper and spayed with CRC. It is much better but still flickers once in a while on power up. There must still be a bit of trash in there, ARRGH! I'll probably go back in there.
Audio Jones, would you have a supplier for that relay & any chance you could give a novice pointers on the installation? I do OK with the mechanicals, as far as the electrical side let's just say I'm improving.
Thanks for all the info gentlemen, maybe after this issue is solved I'll be able to trace the problem with the stereo indicator light (no power to the leads)
at that point it will be100%.
Thanks again, Dave
  #10
Old 05-22-2012, 10:01 PM
Montycat's Avatar
I was almost going to trash this SX-450 before checking out some of the threads on it. I got right into the switch box and it is now pretty clean. It stills sputters a bit too though but is much better and stabilizes fast. I did not, but should, clean the speaker contact points too as shown here:
http://www.audiokarma.org/forums/sho...d.php?t=173215
I'd consider the relay as well.
__________________
AFishNeedsAStereo
Audiokarma
  #11
Old 12-11-2012, 05:23 PM
Montycat's Avatar
I finally decided to pull this SX-450 out of the storage bin and think I will get it back to some better semblance of performance. I think I am simply going to bypass the power switch and possibly insert a panel mounted toggle into the microphone jack for the power on/off.
I wonder if the mike jack has a switching function in it, like a headphone jack might where it shuts off something else when a 1/4" jack is inserted. In other words if I simply detach the mike jack from the PC board will I need to bridge anything there?
The headphone jack would be better placed as it is right beside the power switch, but I or somebody else is more likely to want to use headphones than a mike.
__________________
AFishNeedsAStereo
  #12
Old 12-11-2012, 11:27 PM
BranMPioneer's Avatar
BranMPioneer BranMPioneer is offline
AK Member
go to the pioneer forum there is lots of info there about it
__________________
Things can always be improved. Beware old engineering as newer parts can work miracles sometimes. -My Grandpa
  #13
Old 12-12-2012, 01:55 AM
Montycat's Avatar
Oh, I've been all over looking at it from all directions. I did take the switch apart and clean it too but that's only a stopgap as the arcing will continue.
No I am convinced I will put in another switch. I think I might have just enough room above the headphone jack to drill and mount a pushbutton. I don't think I want to use the mic jack as it does share the Aux input I found from the schematic.
__________________
AFishNeedsAStereo
  #14
Old 12-12-2012, 09:27 PM
Watthour's Avatar
Watthour Watthour is offline
Electron Rancher - JS3600
Check this before you perform any unrecoverable alterations:
http://www.audiokarma.org/forums/sho...d.php?t=372256
The 450 uses a similar arrangement, but probably has a different switch such as this:
__________________
Fighting Ignorance Since 1973 (It's taking a lot longer than we thought)
  #15
Old 12-13-2012, 05:41 AM
Alienz's Avatar
Alienz Alienz is offline
AK Member
Some 2SA725 transistors were causing start up trouble in my SX450, you could try replacing those before you replace the switch.
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Meistertech Solutions
Capacitor World
AudioFriends
Analog Engineering Associates
Vintage Home Audio
Okki Nokki
Hudson Valley Hi Fi
Wargos Electronics
Organ Donor Parts
Parts Connexion
Sound Stage Direct
Take Five Audio
Audience AV
Howard Products
Simply Speakers
The Tube Store
FM DX Antenna
AudioClassics
Many Moons Audio
Audio Doctor
RSL Speakers
Yesterday's Audio
DeWick Repairs
BOI Audio Works
Politicalchat.org
MCM Electronics
Amplifiedparts
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
©Copyright 2002-2015 AudioKarma.org, All rights reserved.
