Audiokarma.org
Audiokarma Featured Sponsor
Audiokarma will be offline March 7th and 8th
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Solid State
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 04-27-2012, 10:12 AM
drabina drabina is offline
AK Member
Luxman L-85V - to rebuild or not to rebuild?
I have Luxman L-85V amplifier with a non-working power amplifier section. The amp is in great condition otherwise and I know it works because I was able to switch the power amp section from another L-85V that I own and it worked. Looking at the PCBs they are a mess. One of them has transistor missing, a lot of parts were replaced, etc. So pretty much the only way to properly fix the amp is to completely rebuild the PCBs. My knowledge is limited but once I gather the replacement parts, I should be able to rebuild them (I did two successful recaps, built two amplifiers and did some other minor soldering work in the past). The problem is, if replacing all the missing and/or not working transistors would yield satisfactory results. Please keep in mind that most of the transistors are no longer in production so I would have to go with replacement ones. They may or may not change the sound.
Here are few pictures of the boards:
picture 1
picture 2
picture 3
What do you think guys?
  #2
Old 04-27-2012, 11:05 AM
Blue Shadow's Avatar
Blue Shadow Blue Shadow is offline
Swapping Gear
I would be all over repopulating those boards. The L-85V is one sweet amplifier and I love the heat sink 'handle' that this amp has. If the cabinet and faceplate are in good shape there would be NO Question about making it a fully functioning integrated amp again.
  #3
Old 04-27-2012, 04:27 PM
AK Member
The rest of the amp is in great condition. Faceplate is almost mint. I am sourcing parts now to see what the cost is going to be and if I can source all the parts that should be replaced. So far I was able to find about 60% of the parts since there are some questions as to the values which do not match the schematic plus the no longer in production transistors. So far the total is about $40.
  #4
Old 04-27-2012, 04:45 PM
Alienz's Avatar
Alienz Alienz is offline
AK Member
If you post those transistors here people can suggest some good modern replacements.
  #5
Old 04-27-2012, 07:38 PM
ryuuoh's Avatar
ryuuoh ryuuoh is offline
FFXIV Summoner
Make sure you have current limiting (a dim bulb tester) before powering it up.
__________________
Akai AS-970 AA-5000S
Technics SU-8080, SL-1300, SL-20, SA-5
Luxman L-80V, L-430, T-240
Yamaha NS-670, NS-690II, NS690III, T-80, T-70, M-50, C-50, CD-S700
Denon TU-800, TU-1500RD
Bozak MB80
Sansui TU-717, 9090
sun tan, drink in hand
Audiokarma
  #6
Old 04-30-2012, 01:03 PM
AK Member
I have the bulb tester and I have posted a request to help me find replacement transistors in this thread. I have decided to create new thread because the transistors are most likely used in other gear as well.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Okki Nokki
Capacitor World
Organ Donor Parts
Vintage Home Audio
Parts Connexion
Wargos Electronics
Take Five Audio
Sonneteer
Audience AV
Sound Stage Direct
Simply Speakers
AudioClassics
Howard Products
The Tube Store
FM DX Antenna
Musical Paradise
Many Moons Audio
McIntosh Cabinets
Yesterday's Audio
BOI Audio Works
DeWick Repairs
Amplifiedparts
Politicalchat.org
RSL Speakers
Audio Doctor
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
ęCopyright 2002-2014 AudioKarma.org, All rights reserved.
