Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Speakers
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 06-13-2012, 04:55 AM
Vinylized's Avatar
Vinylized Vinylized is offline
AK Member
How to connect dual wire Panasonic SB-AK25 to regular amp...
Can anyone of you wise members advise me on the correct way to connect these speakers to a (6Ω) Yamaha RX-550 amp?
They are 6Ω (total) speakers with two separate wires coming out of the back panel. A Google search will give you images...
Can I just wire these together at the same terminal?
Cheers
Anthony
  #2
Old 06-13-2012, 05:33 AM
Tube Radio's Avatar
Tube Radio Tube Radio is offline
AK Member
I doubt it. More than likely the stereo these went with was bi amped which means no crossover in the speakers.
You can add an external passive crossover then use those speakers.
__________________
  #3
Old 06-13-2012, 09:24 AM
SleeperSupra SleeperSupra is offline
AK Member
Just hook them up to your receiver in parallel. These are small speakers and I'm sure any modern amplifier will be able to drive them.
  #4
Old 06-13-2012, 10:27 AM
Tubeage's Avatar
Tubeage Tubeage is offline
Analog Ready
Quote:
That would NOT be advisable unless you want a blown tweeter. The crossover is located inside the original stereo system the speakers came with, which in turn has two separate amplifiers, one for high, and one for low. Hooking both wires up directly to the receiver would not only sound bad, but would probably smoke the tweeters within a matter of seconds or minutes. Don't do it.
__________________
ADS L1090s, Decware ZKIT1's (mono pair), Perreaux 2150b x2, Mackie HR-824v1, Kenwood KD-750- Carts: AT150MLx, Signet TK7E, TK7Ea
  #5
Old 06-13-2012, 10:51 AM
Markw's Avatar
Markw Markw is offline
Banned
Yep, what Tubeage said.
I checked out the owners manual. These are part of an integrated system and are designed to work only with that head unit. They cannot be played with any other amp. Well, not unless you don't care if they don't work again.
Audiokarma
  #6
Old 06-13-2012, 11:03 AM
Tube Radio's Avatar
AK Member
If the op decides to use a passive 2 way crossover those speakers can then be used with most any amp.
__________________
  #7
Old 06-13-2012, 11:28 AM
Markw's Avatar
Banned
Very true.
Quote:
Feel free to provide him with whatever advice he needs to accomplish that.
  #8
Old 06-13-2012, 03:20 PM
Tubeage's Avatar
Analog Ready
That would work. In this case, you connect for each channel (left and right) a speaker wire (+/-) from your receiver to the input of a passive crossover of some kind... and then you would hook up the wires from the speaker's tweeters to the tweeter or "high" and from the woofer to "low" on the crossover.
But then you need to select a frequency where you want the low to leave off and the highs to pick up, so that the speaker will sound balanced best. It might sound complicated, but it's really not.
Hope this helps
__________________
  #9
Old 06-13-2012, 03:27 PM
Tube Radio's Avatar
AK Member
Yep designing a crossover is not really that hard. If you can find out where the stereo these speakers went to crossed them over at that will be even better.
__________________
  #10
Old 06-13-2012, 04:17 PM
Vinylized's Avatar
AK Member
WOW! Thanks guys...with all that info...these speakers are not worth the bother. The unit they came with is probably in landfill somewhere by now as it was cactus! They are actually quite powerful little speakers, so I may keep them as replacement cones for some project down the track.
Cheers
Audiokarma
  #11
Old 06-13-2012, 06:45 PM
Tubeage's Avatar
Analog Ready
Too bad. I like those little systems for a kid's bedroom, or if you have a girlfriend- for her apartment. They really can sound nice, and KICK without going into distortion overdrive. There's only one thing worse than crappy pop music, and that's crappy pop music at 45% distortion
__________________
  #12
Old 06-15-2012, 06:23 PM
Vinylized's Avatar
AK Member
Quote:
Hahaha...EXACTLY!
Yeah, they are quite powerful...I had my PC sound running thru the system and out of these speakers and they produced a whopping amount of power with which to deafen myself with.
  #13
Old 06-15-2012, 07:09 PM
JoeESP9's Avatar
JoeESP9 JoeESP9 is offline
ESL's & tubes since 83
Powerful speakers?
__________________
  #14
Old 06-17-2012, 05:21 AM
Vinylized's Avatar
AK Member
Quote:
Originally Posted by JoeESP9 View Post
Powerful speakers?
Yeah, they are for a bedroom or a garage...
  #15
Old 06-17-2012, 09:40 AM
cablephil212's Avatar
cablephil212 cablephil212 is online now
AK Member
Cheers
Anthony
This is what I found with a Google search: http://service.us.panasonic.com/OPERMANPDF/SCAK25.PDF
On page 36, under the speaker section, it looks like the woofer is x-overed @ 200hz and the fullrange? (mid and tweet maybe) runs wide open.
If I were experimenting with these, I would use (as a starting point) a 4.7uf cap inline with the "fullrange", and let the woofer run full. At least this way, you still keep the 6ohm rating. Who knows, they might sound good.
Or, if you have a spare coil laying around that's around 2mh, wire up the woofer? and let the other be a fullranger.
Either way should still be a safe load on the amp.
Have Fun.
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Hudson Valley Hi Fi
Okki Nokki
Organ Donor Parts
Capacitor World
Parts Connexion
Vintage Home Audio
Take Five Audio
Wargos Electronics
Audience AV
Sonneteer
Simply Speakers
Sound Stage Direct
Howard Products
AudioClassics
FM DX Antenna
The Tube Store
Many Moons Audio
Musical Paradise
Yesterday's Audio
McIntosh Cabinets
DeWick Repairs
BOI Audio Works
Politicalchat.org
Amplifiedparts
Audio Doctor
RSL Speakers
Videokarma.org
MCM Electronics
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
