Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > The Cutting Edge
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 09-04-2012, 08:23 PM
sebrof's Avatar
sebrof sebrof is offline
AK Member
Good Coupling Capacitors - Silver Mica?
A friend of mine loaned me a pair of NOS silver Mica caps for use in my 2A3 SET amp, coupling the driver stage to the output stage. I had Russian paper in oils.
The improvements were pretty significant, and might be summarized as giving a more "airy" sound (exactly why I have a SET in the first place).
The PIOs are .22 uf per the schematic, and the ones he loaned me were .1 uf
Any suggestions on some caps that might be similar?
I attached a pic of a cap that looks pretty close to what he loaned me.
TIA
  #2
Old 09-04-2012, 08:44 PM
BadassBob's Avatar
BadassBob BadassBob is offline
Digitally rendered
Id like to know this as well, Im a sucker for rolling caps. Like you, I run PIOs (Jensens and Ruskies), and love the sound of both of them, but I still feel that I can squeeze out more. Not that I find my PIOs lacking, but I feel theres more to the story. For what its worth, there are lots of Ruskie silver micas on eBay.
__________________
RPi w/ Wolfson card | Parasound Zdac | Music Hall a15.3 | Wharfedale Denton 80th Anniversary
RPi w/ Hifimediy DAC | NAD C350 | B&W DM302
  #3
Old 09-05-2012, 10:04 AM
Mr. Lin's Avatar
Mr. Lin Mr. Lin is offline
AK Subscriber
Interesting, thanks for reporting. Unfortunately I only have experience with the silver mica capacitors that are a lot smaller than the one in the picture.
__________________
  #4
Old 09-05-2012, 10:17 AM
ConradH's Avatar
ConradH ConradH is offline
AK Member
0.1 uF is simply huge for a silver-mica. Be careful in evaluating sound if the values of the caps are different. Changes in the LF response will fool the brain into thinking the treble is different. Only compare identical value caps unless you want to go in circles and fuel the snake oil debates! I'd go with polypropylene or polystyrene. You might also try C0G/NP0 if you can find any that large, possibly a multilayer type or a few in parallel. Avoid all other ceramics.
__________________
Conrad
"Finally, I've got them right where they want me."
  #5
Old 09-05-2012, 04:07 PM
sebrof's Avatar
AK Member
Quote:
Well...care to share?
Audiokarma
  #6
Old 09-05-2012, 04:13 PM
sebrof's Avatar
AK Member
Quote:
Thanks Conrad. Actually I'm not looking to compare, just looking to get the sound back that I heard when his silver micas @ .1uf were in there. So if it was because of the value then that's good to know. If it was because of the materials used then that's good to know also.
Your recommendations are based on using the different types as coupling caps in similar amps to mine or different applications? And you recommend polypropylene or polystyrene over silver mica?
  #7
Old 09-05-2012, 05:35 PM
ConradH's Avatar
AK Member
I'd be foolish to recommend one over the other, as they're all much better than good and I've had excellent results from all, though not in an SET. Silver-mica has surprisingly high dielectric absorption, not to be confused with dissipation factor, and the audibility of that is debatable. Let your ears be your guide, not somebody else's!
__________________
Conrad
  #8
Old 09-10-2012, 03:16 AM
Mr. Lin's Avatar
AK Subscriber
Quote:
To be honest I've only used those in DIY projects where their "audibility" would be highly questionable, and I certainly didn't do any A/B stuff with them. If you're looking for recommendations for .1uf caps in audio, the most popular inexpensive option is polypropylene, usually.
I actually built a pair of Bottlehead Paramour 2A3 mono blocks last year and unfortunately haven't finished the chassis, but I intend to eventually listen to them as-is for a while and then replace the .1uf coupling caps in them with a pair of NOS Russian Teflon capacitors, which are another popular choice these days. You might want to consider those, they're readily available on ebay as they're surplus military parts from the Soviet days. I've read again and again though that they require lengthy break in periods.
The other capacitors I've used for somewhat similar purposes might be more than you're looking to spend, like Audio Note's tin-foil-in-oil version, which is their entry-level cap, and more recently for my Bottlehead Foreplay III tube preamp I've installed Jantzen "Z-Superior" metallized polypropylene w/copper leads. The latter made a very noticeable difference for the better in the Foreplay preamp, namely more clarity and thus more detail in general.
__________________
  #9
Old 09-10-2012, 04:44 AM
Fisherdude's Avatar
Fisherdude Fisherdude is offline
Regular Dude - Super Mod
...Be careful in evaluating sound if the values of the caps are different. Changes in the LF response will fool the brain into thinking the treble is different. Only compare identical value caps...
Ditto this.
Going from .22 to .1 is a significant change in value for a coupling cap, and that alone may affect the sound.
__________________
I may be growing older, but I refuse to grow up.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Analog Engineering Associates
Capacitor World
Okki Nokki
Hudson Valley Hi Fi
Vintage Home Audio
Organ Donor Parts
Parts Connexion
Wargos Electronics
Take Five Audio
Audience AV
Sound Stage Direct
Simply Speakers
Sonneteer
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
McIntosh Cabinets
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Audio Doctor
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
