RobertR
MARANTZ Timeline 1950-2003 - Chronological History of Marantz Company
The following timeline comes from a Stereo Sound special edition dedicated to Marantz published in 2003. The book was meant to be distributed to key people in the industry but not to be available for sale... The quality and thoroughness of it are one thing, the other is that, for once, this Stereo Sound publication saw an english edition !
I'm sure the Stereo Sound editorial dept. won't mind me bringing this online as it will help put an end to the many misconceptions and erroneous assumptions so far present online, especially the Philips/DynaScan/Superscope split ownerships.
I will try later on to bring several other specific features of this sadly unavailable book and will manage to bring the many tidbits of info throughout the pages of TVK.
In the meantime... enjoy !
NICOR http://marantzforum.nl/forum/index.php?topic=8360.100;wap2
Year Key Components Main Time Frame
1911 Saul B. Marantz' birth in Brooklyn on july 11. - - Japan-USA new trade agreement
1923 Sidney Stockton Smith's birth in Winnetka, Illinois. (Marantz Design Engineer)
1951 Saul B. Marantz begins manufacturing the Audio Consolette in New York - - Ultra Linear (UL) circuit
1952 - Audio Consolette (Model 1 original version) vacuum tube monaural preamp. Compliant with 36 types of SP/LP record EQ curves. Two-stage P-K feedback type phono EQ. Uses 12AX7 and 12AU7 in a three-tube structure. 155$ with cabinet, selling at least until 1955.
1953 Marantz Company established in Long Island, New York (4415 Vernon Blvd.) - - RIAA equalizer standard in June.
1953 Standard Wireless Radio Corporation established in Setagaya, Tokyo. SRC was established as Hokushin Kogyo K.K. on may 10,
1946, in Tokyo. - - First TV broadcast by NHK (february) ; first TV broadcast by Nippon Television (NTV) in august.
1954 Sidney Stockton Smith joins Marantz. Model 1 vacuum tube monaural preamp employing RIAA EQ and tape monitor circuit. Two-stage P-K feedback phono EQ ; 12AX7 three-tube structure. With cabinet: 168$>171$ ; without cabinet: 153$. Acoustic Research AR1.
1956 Sidney Stockton Smith is the Chief engineer for the Model 2. Model 2 vacuum tube monaural power-amplifier. Output stage is 6CA7 p-p, output with UL connection 40W, with triode connection 20W. Uses variable damping (VDFC) mechanism, AC/DC balance/bias adjusting mech., triple circuit input terminal. Uses 1x 12AX7/ECC83, 1x 6CG7, 2x 6CA7/EL34 and 2x 6AU4GTA tubes. (198$>219$) -
1957 Marantz Company relocates to 2514 Broadway, Long Island 6, NY.
Model 3 electronic crossover. Monaural 2-way type. 12 selectable frequencies: 100 / 150 / 220 / 350 / 500 / 700Hz / 1 / 1,5 / 2,2 / 3,5 / 5 / 7kHz. 12dB/octave slope. Uses 12AX7 in three-tube structure. Without cab. with power-supply: 90$ ; with cabinet: 105$.
First FM Broadcast test by NHK.
1957 - The Type 4 power-supply can be used with Model 1 or Model 3 ; it uses a selenium rectifier.
1958 - Model 5 vacuum tube monaural power-amplifier. Output stage is 6CA7 p-p, output with UL connection is 30W. Basic circuitry is the same as Model 2, rationalized for use as multi-amplifier. Uses 1x 6BH6, 1x 6CG7, 2x 6CA7/EL34 and 1x GZ34 tubes. Without grille: 147$ ; with grille: 154,50$. AMPEX color VTR.
1958 - Model 6 stereo adapter for Model 1: 45$.
Two types available: Model 6H (vertical) or Model 6V (horizontal). EIA and RIAA establish the 45/45 system as standard for recording and reproducing stereo records
1958 Flavio Blanco participates to the development of the Model 7. Blanco will later be responsible for development and design of the solid-state amps as technical dept. head in the amplifier section of the Company. Model 7 vacuum tube stereo preamplifier released in December. Uses six ECC83/12AX7 tubes, three-stage NF eq and NF step-switch tone control.. Without cabinet: 249$ ; with cabinet: 273$.
1959 In september, Standard Radio Corp. begins production and sales of tape recorders. Model 8(A) vacuum tube stereo power-amplifier. Together with the Model 8B, was the only vacuum tube Type 1 power supply power amplifier produced by Marantz. The Model 8(A) is also know as the stereo model that combines two Model 5 in one chassis. Power supply section is a voltage doubler rectifier system with silicon diode. Output stage is 6CA7 p-p, output with UL connection 2x 30W. Uses 2x 6BH6, 2x 6CG7 and 4x 6CA7/EL34 tubes. Without grille: 237$ ; with grille: 246$. - -
1960 In march, Standard Radio Corp. establishes its new Sagamihara production facility in Sagamihara City, Kanagawa Prefecture. Model 9 and Model 9R vacuum tube monaural power-amplifier. Output stage is 6CA7 parallel p-p, output with UL connection 70W, with triode connection 40W. Uses 2x 6DJ8/ECC88, 1x 6CG7 and 4x 6CA7/EL34 tubes. First vacuum tube amp to use a front panel. Uses active low-cut filter, phase switching, crossover NF circuit and elaborate phase correction. Power supply is a voltage double rectifier with silicon diode.
Standard type: 324$>384$ ; rack-mounted Model 9R: 354$>414$. Acoustic Research AR3.
1961 In march, Standard Radio Corp. establishes its new Sagamihara production facility in Sagamihara City, Kanagawa Prefecture. Model 8B tube stereo power-amplifier, improved version of Model 8(A) with increased output of 2x 35W. Basic circuit of the Model 8B is that of the Model 9, and the Model 8B also uses crossover NF circuitry and elaborate phase correction system. Power supply is a voltage double rectifier with silicon diode. Uses 2x 6BH6, 2x 6CG7 and 4x 6CA7/EL34 tubes. With grille: 258$>273$ ; Without grille: 249$>264$. The FCC adopts Zenith/GE system for standard FM broadcasting.
1961 Richard Sequerra joins Marantz. - - FM stereo broadcasting begins in USA.
1962 Merged into "Standard Radio Corp." (february). SRC begins production of communications eequipment in april. SRC listed in the 2nd tier of Tokyo Stock Exchange (september). Marantz announces a new concept by using an oscilloscope tube for multipath/tuning indicator in a prototype of the Model 10 FM tuner ; The Chief Engineer is Richard Sequerra. - -
1963 Merged into "Standard Radio Corp." (february). SRC begins production of communications eequipment in april. SRC listed in the 2nd tier of Tokyo Stock Exchange (september).
Model 10B vacuum tube FM tuner with 3" oscilloscope. 650$.
Philips releases the first Compact Cassette recorder.
1963 - SLT-12 record player with linear tracking tonearm. -
1964 Superscope takes over management of the Marantz Company in America. - - -
1965 Marantz moves from New York to California. Model 7T solid-state preamplifier, sold through Nippon Gakki in Japan (aka Yamaha). Development of Dolby A noise-reduction. Sony launches the ES series.
1966 Superscope plans to launch mid-range and receiver departments requests developments to japanese manufacturers. SRC's prototype is adopted. Model 15 solid-state stereo power-amplifier ; dual-mono structure, 2x70W (4Ohm). Sold through Nippon Gakki in Japan (aka Yamaha) in 1967, with wood enclosure. 395$. -
1967 - Model 18 solid-state receiver equipped with FM tuner and oscilloscope ; 2x 35W. 595$. - Kenwood Supreme 1
1968 Domestic marketing dept. established as independent body: Standard Sales Corporation (known as STS) is established. Through STS, the domestic sales of Marantz products begins. - - Sheffield Labs markets records made by direct cutting.
1968 Saul B. marantz retires as president of Marantz Co. - - -
1969 SRC establishes a retail company, Standard Communications Corporation USA in Los Angeles in january ; share-holding ratio: 50%. Model 16 solid-state stereo power-amplifier, released through STS. dual-mono structure, 2x100W. NHK begins FM broadcasting. Philips starts working on optical discs read by lasers.
1969 - Imperial Series (I>V) speaker systems released, with Mitsubishi Electric as OEM (aka Diatone).
Only the Imperial III is sold in Japan. - SQ system ready to be launched.
1970 - Saul B. Marantz helps establish the Dahlquist company and becomes a production development consultant together with Sidney Smith.
Model 33 solid-state stereo preamp, 1st model to use differential circuit,
Model 30 solid-state integrated amplifier ; 2x 60W,
Model 22J solid-state receiver ; 2x 40W,
Model 27J solid-state receiver ; 2x 30W.
Model 26J solid-state receiver ; 2x 14W.
Model 24J solid-state preamp with FM/AM tuner,
Model 23J FM/AM tuner. FM Tokyo begins broadcasting.
1971 - Model 32 power-amp (through STS) ; 2x 60W - U-Matic video standard (Sony+JVC)
1971 - Limited importation of Model 20 FM tuner (through STS). The Model 20 is a solid-state tuner based on the Model 10B ; it also is the tuner section of the Model 18 receiver, modded by Marantz' main factory for japanese FM band.
1971 - Model 1200 (through STS) ; 2x 100W. Upgraded version of Model 30, with reinforced power-supply and produced completely with printed circuit boards.
1971 - Model 250 power-amplifier (through STS) ; 2x 125W. Left/Right unified and reinforced power-supply.
1971 SRC increases capital through third-party capitalization by Superscope in october ; share-holding: 50%.
Model 500 power-amplifier announced ; 19" rack-mount type.
