Radex7 PM'd me a question about my cap list, and I thought it better to respond on the forum. This is a great little unit. Easy to work on and well worth a recap. Mine sounds good, but this was the first cap list I made and I would do it differently now. In the original list I used mostly KL series with a few HE series in the power supply. Now I'd use primarily Nichicon PW for power smoothing caps everywhere. For signal caps I'd use film for values 10uF and under, and KL series for larger signal caps. Haven't picked out the main filter caps - size and mounting are considerations there. If anyone starts with this list, scrub it carefully for errors. This is about $60 worth of part (plus the main filter caps). About half of that is 10uF WIMA films (8 of em). These could be replaced with KL series to lower the cost. There are also some transistors that should be replaced - definitely the 2SC458 in the driver boards. I've also seen threads where the 2SC693 have become noisy. KSC1845 are good replacements.
F-1251 Power
C002 100uF 75V UPW2A101MHD
C003 330uF 10V UPW1E331MPD6
F-1246 Ripple
C005 330uF 16V UPW1E331MPD6
C007 220uF 25V UPW1E221MPD
C009 330uF 25V UPW1E331MPD6
C010 100uF 25V UPW1E101MED
Other
C053 2200uF 50V UFW1H472MRD
C054 2200uF 50V UFW1H472MRD
C055 2200uF 75V ?
C056 1000uF 50V ?
F-1240 Tone
C705 1uF 50V ECQ-V1H105JL
C706 1uF 50V ECQ-V1H105JL
C707 10uF 25V MKS2B051001N00MSSD
C708 10uF 25V MKS2B051001N00MSSD
C715 10uF 25V MKS2B051001N00MSSD
C716 10uF 25V MKS2B051001N00MSSD
C717 3.3uF 25V MKS2B043301H00KA00
C718 3.3uF 25V MKS2B043301H00KA00
C721 33uF 6.3V UKL1E330MEDANA
C722 33uF 6.3V UKL1E330MEDANA
C723 3.3uF 25V MKS2B043301H00KA00
C724 3.3uF 25V MKS2B043301H00KA00
F-1180A Driver
C802 100uF 25V UPW1E101MED
C803 220uF 10V UPW1E221MPD
C804 10uF 25V MKS2B051001N00MSSD
C805 33uF 50V UKL1H330MPDANATD
C806 100uF 6.3V UPW1E101MED
C807 3.3uF 50V MKS2B043301H00KA00
C812 100uF 25V UPW1E101MED
C813 220uF 10V UPW1E221MPD
C814 10uF 25V MKS2B051001N00MSSD
C815 33uF 50V UKL1H330MPDANATD
C816 100uF 6.3V UPW1E101MED
C817 3.3uF 50V MKS2B043301H00KA00
F-1241 Equalizer
C601 1.5uF 15V MKS2B041501E00KSSD
C602 1.5uF 15V MKS2B041501E00KSSD
C605 100uF 6.3V UPW1E101MED
C606 100uF 6.3V UPW1E101MED
C609 47uF 6.3V UKL1H470MPDANA
C610 47uF 6.3V UKL1H470MPDANA
C611 10uF 25V MKS2B051001N00MSSD
C612 10uF 25V MKS2B051001N00MSSD
C613 0.33uF 25V ECQ-V1H334JL3
C614 0.33uF 25V ECQ-V1H334JL3
F-1239C Multiplex
C401 3.3uF 25V UKL1H3R3KDDANA
C408 1uF 50V ECQ-V1H105JL
C410 47uF 16V UPW1C470MDD
C417 100uF 25V UPW1E101MED
C418 3.3uF 25V UKL1H3R3KDDANA
C419 10uF 10V UPW1E100MDD
C420 1uF 50V ECQ-V1H105JL
F-1244 FM
C215 1uF 50V ECQ-V1H105JL
C220 10uF 10V UPW1E100MDD
C223 3.3uF 16V UKL1H3R3KDDANA
C236 1uF 50V ECQ-V1H105JL
F-1259 AM
C305 3.3uF 16V UKL1H3R3KDDANA
C312 10uF 16V UPW1E100MDD
C314 10uF 16V UPW1E100MDD
C324 100uF 6.3V UPW1E101MED
C326 100uF 16V UPW1E101MED
