Anyone wanna chime in with my little firestarter, or is anyone on here within a hundred miles of manchester got the equipment and ability to help me sort this bastard out !!
I need 1 npn output transistor however i really need to get this right because i hate destroying parts that are hard to find its terribly wasteful, is it worth me replacing every transistor on the driver boards faulty channel ? should i swap the polystrenes for micas ? im gonna drag the preamp out n look at that, amp has only been used through the aux input fed from a dac wired to the pc !
I measured voltages from the power supply before when i rebuilt it n they were fine ! I've performed diode checks on all transistors/diodes and compared them to the working channel also measured the resistance across the pins bce and theyre comparable ! all resistors were measured and were within tolerance values.
My current failure list R31 R75 R91 R87 c65 Tr29 tr31 n the 4 o.p trannys
