Morden2004
Relaxin'
Morden2004 makes a 'J' pole antenna! And it works!
After reading the 'J' pole thread elsewhere in this forum, I decided that it was a good project for me. I recall years ago making one out of 12 ga.wire just for fun and it was quite the performer.
My first stop, Home Hardware for the pipe and fittings. I decided early on that I would beef-up the bottom (support) section to ¾” pipe so one of my parts was a 1/2x1/2x3/4 ‘T’.
With all the physical hardware in hand I made my next stop at Radio Shack (now called ‘TheSourceCC’ in Canada (the CC is Circuit City) and I parked myself in the RF/Cable isle. I always leave final decisions as to wiring until I can check out the bits in the bins on the shelves. I was lucky this time because I found a perfect component to interface the RG-6 co-ax to the antenna stub; see picture #1 below.
This is a 75 ohm grounding block RS# 1500909 for satellite cabling, but it will become my primary connection to the antenna and will allow me to run a ‘un-cut’ 50’ RG-6 cable end-to-end. I always like it better when I don’t have to jury-rig a new connection to factory-terminated co-ax. Factory connections are both stronger and are weather-proof. Mine often fail on both counts.
I cut the sections to 100 MHz as a good center frequency. Then I soldered together the basic antenna and cut two pieces of wood to tie together the ¼ wave stub to the ¾ wave rod. I fabricated these simple wooden tie bars (two) with one large hole and one tight hole. These slip down over the two sides with a little tapping with a rubber mallet. The large hole has a sharp-pointed screw to lock the bar in place.
Picture #2 shows the ‘working end’ of the ‘J’ antenna with the grounding block located on the lower tie-bar at about 5” above the cross-over. I think you can now visualize how the co-ax will connect and how I will extend the other connector with solid copper wire to become the split-T connection to the antenna. Picture #3 and picture #4 shows why I was so happy to find that grounding block! Picture #4 shows the completed wiring with the RG-6 connected. I will create a small loop in to co-ax below the antenna and wire wrap it to the support to be a strain relief for the co-ax.
Next, I’m going to stand this baby in my stair well (I have 7 foot ceilings in this old house, so can’t stand it up in my living room
) and see how it performs.
Paul
<IMAGES NO LONGER AVAILABLE>
) and see how it performs.Paul
