Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Turntables
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 12-06-2013, 02:09 AM
Roivas's Avatar
Roivas Roivas is offline
AK Member
Orbit Plus Review - The Prodigal Deck Arrives
Before I begin, I will preface this by saying that it is not a scientific review. I do not own the kind of equipment needed to make measurements. I can only tell what I have actually heard and experienced.
When I received the Orbit in the mail, it was decidedly smaller than I expected. I use an SL-1610 normally, and in comparison this is small and light.
However, it fits nicely on a shelf. I was surprised when I looked underneath and saw that the Orbit balances on three feet instead of four. This was to be the first of several things that struck me about how this turntable is different.
My Orbit is not the standard $179 model. This is the Orbit Plus, which is $100 more. I had a strange mixture of expectations because of this. On one hand, the people at U-Turn Audio are aiming for new, budget conscious listeners. They want to create a low-cost turntable that sounds great. They make no claims about taking down pricier gear, but they do want the Orbit to be a device to entice burgeoning audiophiles. Do you compare the Orbit (or Orbit Plus) to the Crosleyís of the world? Or should it be compared to something a bit higher up?
I decided that what I ought to do first was play the Orbit as most of its intended audience would hear it, without listening to other gear. I plugged it into an ART DJ II preamp and into the AUX input on an old Receiver.
Setting up the Orbit Plus takes less than 5 minutes. It is an absurdly easy process. Everything is well-packed. Initial impressions are that it feels light. The plinth feels sturdy, but the dust cover is thin. Not so thin that it feels overly weak, but youíd never want to put anything on top of it.
Hitting power for the first time, there is a slight squeak from the motor spindle that makes me cringe. I suddenly worry that this might be what some detractors have warned about from the beginning. However, the tonearm feels nice in the hand as I pull it off of the rest.
Before going further, the tonearm rest is reallyÖweird. Itís somewhat flexible, which is not like any turntable Iíve seen. Instead of rigid plastic or metal, it has just enough give that it can flex. This means that there are no moving parts like on many vintage tables, which have an armrest which has a sliding piece to lock the tonearm. This rest does that by itself, and relies on just the right amount of directional force from you to pull the arm free. Itís a strange change, but after using it for a few records it made tremendous sense. Thereís a satisfying way in which the arm feels secure when you replace it, and the non-rigid oddness fades away quickly. Iím not sure I would say I prefer this to the old way, though I suspect it is less likely to snap off over time. It certainly isnít worse than the other way.
Much has been made about the Orbitís lack of a cuing lever. I sympathize with those who feel that this is a deal-breaker. However, I will say that the headshell is designed with a long fingerhold that is easy to grab. It naturally allows you to lower the needle into place. If you have a condition that causes shaky hands, this probably isnít consolation. To everyone else, however, the lack of a lever should not dissuade you.
I played a few different records to test the Orbit. I used a UK first press of Abbey Road as the first listen, just because I love that record. Then, I used all newer pressings because that's what I suspect will be played on this thing for most people.
All worries about the motor were erased when the needle touched the record. There was no audible wow & flutter. The Orbit has kept perfect speed for every single part of my listening so far. The way the belt gears tilt when adding the belt was, again, something that was different for me. However, they straighten out once the belt is secure and, after a few minutes of playback, Iíd completely forgotten about it. Instead, I was listening to the music.
I canít speak for the sound of the regular Orbit, but the Orbit Plus sounds great. There is no heavy coloration or distortion of music. The cart brings out a solid amount of detail. I was worried about the idea of the table being internally grounded, but it was never a problem. There was no hum whatsoever on my unit.
However, it is not perfect. Pops from surface imperfections, a necessary evil when playing vinyl, are more noticeable on the Orbit Plus. This is not to say that itís overpowering, but the sound of very high-level clicks were more noticeable here. Also, on the play-through of Abbey Road, the Orbit got caught in a skip-loop halfway through ďI Want You (Sheís So Heavy)Ē that has never gotten caught on my Technics. I put the record onto the other table to see if the skip was something new (my heart skipped a beat or two) but it played through fine.
So, my analysis of the Orbit arm is that it is very good at bringing out the sound thatís in the groove, but it is very light and that low-inertia makes it more prone to skipping or picking up surface noise than what Iím used to on vintage decks.
I used several records, one of which is prone to severe inner groove distortion. The only table thatís ever played it well is a linear tracker, and I personally dub this record as my gauntlet test.
With the Orbit, there was virtually no distortion at all. It was second only to my linear tracker playing back the innermost part of that record. I was impressed & surprised. This was one of the moments where the Orbit really made me smile (there were quite a few).
I played a few ELO records, the new Music on Vinyl reissues that sound simply supurb. These records have a lot of things going on, with dense layers of instruments, vocals, and beats all coming together. That balance that made ELO such a different-sounding band also serve to make them a good test for audio equipment.
Both A New World Record and Eldorado received multiple listens. In both cases, there were no clear flaws in the playback. The Orbit Plus made them sound rich and full, and I found my toe tapping to songs like ďLiving ThingĒ and ďCanít Get You Out of My Head.Ē
One thing to mention: the Orbitís motor has relatively low torque, so the record slowed down when I used my brush on the records. It's not so much a flaw as an observation. Once the brush was gone, the record was back up to speed within a single revolution. However, for someone used to direct drives, it was certainly something I noticed.
Moving on, the audio cables are interchangeable. This is nice if you are the sort of person that has your own high-end cables, but the supplied RCAs are fine. They do what RCA cables are supposed to do.
The wall-wart is large, but it's off-the-shelf. It's easily replaceable. Also, I like seeing the serial number of my Orbit on the bottom, just above the name of the person who approved my table for shipment. Apparently, my table was approved by "SALT," who signed the label for my Orbit, serial #506.
Everything on this table feels as though it has a purpose to it. The legs provide perfect balance. Everything is rigid and squared-way where it needs to be. This does not feel like a device that was cobbled together, nor does it feel homemade. It feels like a professional product. The quality of its construction is clearly superior to the budget tables Iíve seen. The platter is solid and perfectly balanced. It slid onto the spindle effortlessly and there was no wobble or unevenness to playback. It is clearly precisely machined. The coloring of the deck is excellent. I would highly recommend the blue version. It really stands out in a nice way. Again, not a HUGE deal, but itís a detail that shows that a lot of effort and thought was put into this.
So, with all that being said, the Orbit Plus Turntable feels like a good first turntable. It is basic. However, there are enough details that are done right here that I would notice the lack of them on another table without them. The Orbit feels like its own thing, for better or for worse. And in my opinion, that was mostly for the better. Itís not perfect, but it never claims to be.
When comparing it to other turntables, all vintage decks, I immediately felt that this was similar to a perfectly-maintained Technics SL-D2. For many, this is a solid table that served as a reliable workhorse. I doubt that the Orbit could put up with quite as much abuse as that. If someone doesnít care about new vs. vintage, I think these would be equals. The Orbit absolutely sounds better than the SL-D2, but theyíre in the same ballpark. Thatís a good thing, as the D2 remains a great table.
However, I doubt the Orbit is as sturdy as that one is. Of course, few tables ever were as sturdy as the D2, which is why there are still so many of those around. And because the Orbit is new, comes with a warranty, and because vintage gear is undeniably a hit-and-miss, this would be a solid recommendation for someone who wanted the most sound for their money.
Without spending a bit more, youíd be hard-pressed to find a table that sounds this good. It mostly gets out of the way of the music, with just enough engineering to allow it to bring out the best of whatís on the record. Itís not over-designed. The care that went into it is evident. Again, itís not going to dethrone any of the super-high-priced rigs out there. But itís no slouch.
For price and by virtue of the fact that it has none of the pitfalls of vintage gear, I think that the Orbit should absolutely become a go-to recommendation for those trying to put together a system on a budget.
Tomorrow, I'll add a video to augment this. Iíll highlight a few things I didnít post here. If anyone has any questions, post them and Iíll answer as many as I can.
If youíve gotten this far, thanks for reading. I hope this was enjoyable and/or helpful.
__________________
"I love playin' with fire, but I don't want to get burned,
I love playin' with fire, and I don't think I'll ever learn!"
  #2
Old 12-06-2013, 02:14 AM
wushuliu's Avatar
wushuliu wushuliu is offline
AK Member
Outstanding review. Which cart is on this again?
__________________
Jeff Bagby-designed RS180 MTM
Kenwood Trio PC 350U Belt-Idler
Hagerman Bugle
PGA2310 Preamp/TPA3116 Class D Amplifier
Jplay/MQN
  #3
Old 12-06-2013, 02:18 AM
Roivas's Avatar
AK Member
Quote:
Thanks!
Mine came with the Ortofon OM 5E. I think that's what everyone who ordered the Orbit Plus through Kickstarter are getting, and then they're switching to the AT cart. Not sure what the reason for the change is, though that is a very respected cartridge from my understanding.
__________________
  #4
Old 12-06-2013, 02:47 AM
Montycat's Avatar
Montycat Montycat is offline
Ĺ ļ į Ω μf β ų ≠ ∞ ≤ ≥ Ī
Great! Thanks for the review.
It sounds like they have hit a triple if not a home run with this and I am glad to hear it. I do have a few comments on some of the topics you address.
- 3 feet is a good thing as it makes it easier to level than 4. The 2 Regas I have had used 3 feet and I felt it worked well
- Also my Rega were low torque as is my AR. An observation as well but not a complaint.
- The enhanced surface noise may simply be the different "voicing" in the cartridge design compared to what you are used to. If you were to have the same cartridge with similar mileage on both old and new tables that would be more telling.
- The one piece tonearm rest design also can be compared with some venerable designs like AR and Thorens, and that's not bad company. They were not without their flaws but they kept it simple.
Once again, thanks for the well done description of the Orbit.
__________________
"Crisp and clear with every note as bright as the stars in the eyes of the girl youíre dancing with."
AFishNeedsAStereo
  #5
Old 12-06-2013, 06:18 AM
beatcomber's Avatar
beatcomber beatcomber is offline
AK Member
Thanks so much for the detailed review!
This is not uncommon for a belt drive with a low-torque motor.
Quote:
Also, on the play-through of Abbey Road, the Orbit got caught in a skip-loop halfway through “I Want You (She’s So Heavy)” that has never gotten caught on my Technics. I put the record onto the other table to see if the skip was something new (my heart skipped a beat or two) but it played through fine.
Hmmm, this is not good. Did you verify that the VTF setting was correct?
__________________
'61 Thorens TD-124 w/SME 3009 S2 + Grado 8MR/MCZ | marcmorin-ified c.'64 AR-TX + Grado G2/8MZ | Rek-O-Kut L-34/ROK 160 + GE VRII | Dual 1019, 1219
c.'67 Fisher 400 | Yamaha CR-1020 | '78 Pioneer SX-780 | Rotel RCD-1072 | Teac A-2340 | KEF LS50 | '67 AR4x
Audiokarma
  #6
Old 12-06-2013, 06:37 AM
Naptown Rob's Avatar
Naptown Rob Naptown Rob is offline
Ponographer
Thanks for a very well written review. I'm one of many here who has been curious.
__________________
The Last of the Independents: WRNR
  #7
Old 12-06-2013, 06:50 AM
datafone datafone is offline
AK Member
Nice review
Over all It's looking good for an entry level deck.
  #8
Old 12-06-2013, 07:05 AM
iLUVanalog iLUVanalog is offline
AK Member
[QUOTE=Montycat;7342889]Great! Thanks for the review.
Not to worry about the tonearm rest. I had a similar situation with my AudioQuest PT6 tonearm...an arm that by itself cost more than the complete Orbit table. It too had a "soft" tonearm rest and I never had a problem.
  #9
Old 12-06-2013, 07:46 AM
MRL_Audio's Avatar
MRL_Audio MRL_Audio is offline
AK Member
Thanks for the great reviews. Comments like this increase my patience as I wait for my Orbit+ to arrive. Kickstart backer but made my contribution on the second to last day so I assume I near the end of the shipping list. Looking forward to the video.
  #10
Old 12-06-2013, 08:52 AM
KOWHeigel's Avatar
KOWHeigel KOWHeigel is offline
High Gear of Your Soul
Excellent review. I would echo beatcomber's sentiments that VTF should be double checked when the unit is received.
__________________
Analog: VPI Classic, VPI 16.5, Hypnotoad AD797 w/ OPS, AT OC9/MLii
Digital: Schiit Modi, HRT MS II, Sony PS1, SBT clone
Amps: Decware Torii Mk. II, Arcam Alpha 10
Speakers: Decware MG944, ADS L880
Audiokarma
  #11
Old 12-06-2013, 09:00 AM
botrytis's Avatar
botrytis botrytis is offline
Small Speaker Hoarder
Thanks for the review - it is nice to see a new company building a good entrance TT.
__________________
"A man is never more truthful than when he acknowledges himself a liar.'
- Mark Twain
Current Office System: PC --> iFi Nano DAC --> ARC SP-16 --> Denon POA-2200 or Pass ACA monoblocks --> Royd Abbots
JUST BLISS!!!!
  #12
Old 12-06-2013, 09:08 AM
jkilla's Avatar
jkilla jkilla is online now
Out of Touch
Great review, not going to lie, I want this to do well, so I'm ecstatic to hear you enjoy yours much!
The tonearm rest on my Denon turntable also has that kind of construction, it is quite robust so that's a good thing!
Sent from my SGH-T999V using Tapatalk
__________________
Avid Ingenium - Jelco 750D - Jasmine LP2.0 SE MK II
Sony PS-FL1 & Denon DP-1200
TPA 3116 DIY amp - PSB Alpha B1 - and a boat load of carts
  #13
Old 12-06-2013, 09:32 AM
kermit z's Avatar
kermit z kermit z is offline
AK Member
Thanks for the review Sounds like a nice entry level table worthy of a recommendation.
__________________
Main system- Yamaha M-70/Vincent SA-31-PHO-111/Sansui TU-717/TEAC A-3300SX/Marantz CD5004/Technics SL1300MK2 w Denon DL-160/Boston Acoustic A400/Dahlquist DQM-3
Living Room-Onkyo M-501/KenBasicC1/Nakamichi 480/SonyCDP-CA70ES/Akai GX-265D/Pro-Ject RM1.3/Polk Monitor 10B
  #14
Old 12-06-2013, 09:35 AM
fiddlefye's Avatar
fiddlefye fiddlefye is offline
AK Member
Location: Windsor, Ontario, Canada (across the river from Detroit)
Great review. Thanks! It does sound like the acrylic platter version is worth the extra money if one can afford it. The quality comparison to a SL-D2 is a useful one as many have either owned or heard one. If U-Turn has made a better-sounding table for the selling price then it is a real achievement, especially given that the current price of used D2s is starting to creep up into the range of the base table new.
__________________
Current Main-Conrad Johnson PV-12, MV-45/MC 250, Consonance PM1 phono pre, Ariston RD11s/SME 3009/Rek-O-Kut B12H/Fidelity Research FR-24-Denon DCD 1520/CIAudio VDA-2 DAC/VAC-1-Revox A77-Teac C-3RX-Magnum Dynalab/Scott 333b tuners-Reference 3A mm de Capo i
  #15
Old 12-06-2013, 09:37 AM
grottyash grottyash is offline
AK Member
Quote:
That could also be the tonearm, not all of which track equally.
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Analog Engineering Associates
Capacitor World
Okki Nokki
Hudson Valley Hi Fi
Vintage Home Audio
Organ Donor Parts
Parts Connexion
Wargos Electronics
Take Five Audio
Audience AV
Sound Stage Direct
Simply Speakers
Sonneteer
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
Audio Doctor
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
©Copyright 2002-2015 AudioKarma.org, All rights reserved.
