Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Vintage Solid State
We appreciate your help
in keeping this site going.
FORUM RULES
Reply
Thread Tools Display Modes
  #1
Old 03-19-2003, 01:47 AM
EchoWars's Avatar
EchoWars EchoWars is offline
Lee Ho Fook's or Bust
Amplifier Distortion, DC-Offset, and You!
Time for one of those long, boring semi-technical posts that no one here reads...
As a few of you know, I bought a rare Kenwood 700M amplifier a few weeks ago on eBay. It arrived with a weak channel which was taken care of by replacing a bypass cap. Since then, I have gone through the entire amp and replaced all the electrolytic capacitors with the exception of the big power supply caps (not that expensive...maybe $20 in caps).
The previous owner described the amp as 'perfect' sounding, and compared with the big Mac's and Krell's and such. Before buying it, he described his current system which was quite high-end. I assumed that since he owned expensive equipment that he knew what he was listening to.
Got the amp back together today (parts finally in), and fired it up with my small Dynaudio's (can't use the Heil/Dynaudio's for this, as they are bi-amped). Ummm...it sounded like ass. OK, it didn't always sound like ass, but at low volume levels it was obvious that something was wrong. I had a pretty good idea what was going on, so I grabbed my meter. Sure enough, there was 100mV of DC offset in the left channel, and almost 250mV (!!!) in the right! 250mV is almost enough for the protection circuitry to kick in!! Not good. I pulled the driver boards out and replaced the amp input differential pairs for both channels with new Zetex HG PNP's ($5 in transistors, no biggie). DC offset is now about 12mV in both channels. An input pair being as unbalanced as the Kenwood was when it arrived probably generates 10x the distortion as a properly balanced pair, especially at low volume. If you would like to read more about the benefits of a balanced differential pair, read here.
OK, sit down for another listen. NOW we're cookin'!! Amazing night and day difference. I can honestly say that it is without a doubt the nicest amp I have ever listened to, and there have been more than a few that impressed me. The bottom end on this thing is as clear as spring water, and it has an openess that is difficult to describe. As for power, my dummy loads cannot take the power output of this thing, but I can crank it for 10-15 seconds without destroying them. Left channel - 218W before clip, right channel - 220W, this into 8-ohms. Totally cool!! I just have never heard bass like this...wow...
Bottom line...if you expect to hear great sound, you just might...regardless of the reality. The guy I bought this from was well-meaning, but did not know how to listen subjectively. His new spendy amps could be performing horribly, and his expectations of what he felt he was supposed to hear would rule out anything to the contrary.
Your own subjectivity could be suffering too, so give yourself a reality-check.
As a semi-poll, I'd like to see those on this board whip out their multimeters and take a look at the DC that is being presented to the speakers. This means..
1. Speakers disconnected (or connect the meter to the 'B' speakers and set the front panel speaker control accordingly)
2. Input set to an unusued position (not Phono)
3. Volume control at minimum.
4. Balance in center
5. Tone controls either defeated or set to mid position
6. Set your meter to read DC, and set to a low scale (300mV scale is common) Connect directly to the Pos and Neg of the speaker terminals
7. Give the amp 10 minutes to settle. Report back...I'd like to see how healthy all these old amps are.
If you read:
0 - 15mV: Damn good!! If you read '0V', you may have a capacitor output, or your meter is set wrong
16mV - 50mV: An acceptable value, especially at the lower end of this range. 2nd harmonic distortion is probably twice to four times what manufacturer's spec calls for at higher frequencies. Probably not audible, as the distortion is mostly in the upper octaves. At the upper end of this range I begin to raise an eyebrow.
50 - 85mV: Something is certainly amiss, and while this is not enough to put your speakers or equipment in jeopardy, the amp is running nowhere near where it should. I'd venture to guess that most of the DC-coupled amps that are in use by forum members here fall into this range.
100mV to ?: A high enough voltage will cause the DC protection to kick in. This happens at a level determined by the designer, but is usually equivalent to about a diode drop (600mV)or so. Needless to say, if you are listening to an amp with 100mV or more of DC offset, you have no idea what the amp really is supposed to sound like. Indeed, some amps without a differential input are actually designed to have a bit of DC at the outputs, but this is triple-rare, and I don't think anyone here owns one. (in my book it's piss-poor design, but if you can sell it WTH..)
Soooooo...go grab a meter and tell me what you find...
Quote:
Edit:***WARNING!!!***
Since the start of this thread, which was simply intended to have people LOOK at offset, many have decided that they want to try and ADJUST it.
***DO NOT TRY TO ADJUST OFFSET OR ANY OTHER DAMN THING INSIDE YOUR AMP OR RECEIVER UNLESS YOU REALLY REALLY REALLY KNOW WHAT YOU ARE DOING!!!***
I can forward you emails and AK thread links concerning guys who have destroyed their amps/receivers because they thought that all that they has to do was 'a little tweak'. Instead, they cranked up the bias pot instead of the offset pot, either because their amp/receiver HAS no offset adjust (many don't), or because they picked the wrong pot to tweak. OR, a slip of the probe lead and POOF! goes the output transistors and many other parts. So read and re-read the ***ALL CAPS*** statement above until you fully comprehend it.
...and buy the damn service manual!
Quote:
'Nother Edit: ***ATTENTION!!***
Reading negative numbers at the output? Not an issue. Read here.
  #2
Old 03-19-2003, 02:25 AM
ProAc_Fan's Avatar
ProAc_Fan ProAc_Fan is offline
AK Member
Great info Echo now I gotta break out my meter and check. BTW my Yamaha receiver keeps blowing its protection fuse. It's rated at 5A 250mV but I only had a 3A lying around the house so I tried that one. It blew immediately. Do you think there's something amiss of do I just need a 5A fuse? I had been getting a weird click through the speakers when the relay clicked in at startup. Then I went to adjust the volume a little higher( not loud at all) and the same click could be heard before the fuse exploded. The amp sounded fine other than that click at startup. Any ideas?
Mike
__________________
Have you ever noticed? Anybody going slower than you is an idiot, and anyone going faster than you is a moron.
  #3
Old 03-19-2003, 02:37 AM
ProAc_Fan's Avatar
AK Member
Okay my Musical Fidelity amp readings were 10.9mV and 0.5mV. Can that make any sense?
Mike
__________________
  #4
Old 03-19-2003, 03:15 AM
EchoWars's Avatar
The MF amp is pretty decent if those are your readings.
As far as the Yammy, a rule of thumb in troubleshooting is...fix the obvious first. In your case, it would be the fuse.
A chunk of DC offset can certainly cause a nasty thump on turn-on. Get a proper fuse and take a look.
  #5
Old 03-19-2003, 11:16 AM
mhardy6647's Avatar
mhardy6647 mhardy6647 is offline
AK Member
A (semi) aside...
I once cooked two speakers with an "as-found" Technics SA-200 BEFORE I checked for DC on the outputs. One channel had something like 32VDC on it! The output fuses on that little receiver were still intact (unlike the VC's in the two speakers I cooked). Now, I always check for DC on an "unknown" receiver's output before trying a real speaker on it.
__________________
all the best,
mrh
Audiokarma
  #6
Old 03-19-2003, 11:46 AM
ProAc_Fan's Avatar
AK Member
Hey Echo I replaced the fuse with the proper 5A 250VAC fast blow fuse and it again exploded on power up. Any ideas? How can I trouble shoot the problem when it can't be turned on?
Mike
__________________
  #7
Old 03-19-2003, 12:16 PM
grumpy's Avatar
grumpy grumpy is offline
Admin
1.7mv and 1.3mv here on my McIntosh 2205.
Grumpy
  #8
Old 03-19-2003, 01:24 PM
oldmarantz's Avatar
oldmarantz oldmarantz is offline
MarantzManiac
No no EW I m not bored with technical post I like that.Remember the Kenwood ka 4200!!
I ve got the head at this time on a Marantz 1070 bought for 5 bucks...The DC offset for the left channel is 3 V ...
the right channel is perfect I interchanged all the Tr between the L and the R the pb is the same always the same failure on the Left !!!!?????All the voltage measurements after the first driver "A class" are wrong .I think I ve got a contact problem and this time I ve got the SM.
AH for the Setton it seems quite good 30 and 35 mV...
Dom.
  #9
Old 03-19-2003, 06:02 PM
EchoWars's Avatar
ProAC_Fan...sounds like the Yamaha has shorted transistors, either the output pair or the drivers.
Grumpy...Exceptional values! I suspect that the Mac has a potentiometer to adjust the DC offset, as it is nearly impossible to achieve this value with transistor matching alone.
OldMarantz...if ALL the voltage measurements are off, you have lost a ground connection somewhere. Clip a jumper lead from the true ground (the zero reference in the center of the power supply caps) and connect it to a suitable ground point on the channel that is giving you the trouble.
This is interesting. I'd like to see some more...
  #10
Old 03-19-2003, 06:37 PM
THOR's Avatar
THOR THOR is offline
Fearless Prophet
Whats a multimeter
__________________
"That ain't a beer belly son, thats a gas tank for an asswhooping machine!"
Audiokarma
  #11
Old 03-19-2003, 07:04 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Warp engines back online
Here are a few I tried:
Pioneer SX-838: 65.2 mV right/159.4 mV left
Sansui QRX-7500 6.6 mV right/3.9 mV left
McIntosh MAC1900 14.2 mV right/16.2 left
This is amazing! EchoWars, you're awesome!
__________________
"He had never slept in a better bed, Rainsford decided." ~Richard Connell
  #12
Old 03-19-2003, 07:43 PM
Kamakiri's Avatar
And SOB if you're not right about a problem....went to hook up the SX-838 and give it some airtime tonight, and when I thought I had turned the volume down, the damn pot was seized solid!!!! WTF! I was using it last week!
Ah well.....
__________________
  #13
Old 03-19-2003, 07:48 PM
gonefishin's Avatar
gonefishin gonefishin is offline
Banned
Nice idea fer a post echo...echo (almost missed it myself...as I don't visit the SS vintage forum that often)
I'll give this a try...but not tonight...I got some more speaker buildin' ta do!
thanks...later>>>>>
  #14
Old 03-19-2003, 07:53 PM
THOR's Avatar
Fearless Prophet
Are multimeters expensive?? I would like to try this since I have 5 high wattage vintage amps and would like to be sure everything is OK.
__________________
  #15
Old 03-19-2003, 08:00 PM
EchoWars's Avatar
Quote:
Originally posted by THOR
Whats a multimeter
You're kidding, right?
With all the equipment you own, I'd think it would be a basic necessity. A trip to your local RatShack and you can score a decent one. The older ones were made by Fluke (not sure if they still are, but they appear to be).
Here's a pretty decent one on sale.
Kamakiri, If it's broken, it can be fixed. I'd think the volume control problem might be a pain, but the DC offset is actually easy to cure with a service manual and a few transistors. And some amps/receivers actually have a pot to zero the offset (not enough, IMHO). But rarely is the pot designed to zero an error as large as 150mV, which usually means a significant imbalance in the differential transistor pair.
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
AudioClassics
Grant Fidelity
Turntable Depot
DIY Hi Fi Supply
Audio Doctor
Simply Speakers
Afforable$
DeWick Repairs
Audio Art Cable
Parts Connexion
Audio Atlanta
Audience-AV.com
Sound Stage Direct
Vintage Electronics Repair
FM DX Antenna
McIntosh Cabinets
Yesterday's Audio
Zebra Cables
Radio X
Venus HI-FI
vancouver audio speaker clinic
MCM Electronics
Politicalchat.org
Videokarma.org
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
©Copyright 2002-2009 AudioKarma.org, All rights reserved.
