OK...so whatta do? You got a SX-1980 with blown output transistors. You can still find the PNP's around, and even Pioneer shows them available on their website (for about $50 each). But what the hell good is that if the NPN's are gone? Well, the answer is 'not much'.
The original 2SB706A's and 2SD746A's were pretty unique devices. But it has now been some time since you could order some up from Pioneer (or anyone else). Thing is, there are good transistors out there, but making them work is going to be tricky.
What I want to do is to replace ALL the output devices on a SX-1980 with new On-Semi MJL4281A's and MJL4302A's.
Let's compare specs:
An entire set of 12 new On-Semi transistors can be bought for well under $100. Looks like a real bargan if you can make 'em work. The only real concern here is the much higher ft of the new transistors. The possibility of oscillation exists, but that can be addressed if necessary. First things first...find a way to get the things mounted.
Here's the stock setup as delivered to me. The last clown went crazy cutting wires, which in reality is not a big deal, since this whole mess will have to be rewired for the new transistors. Every transistor is blown. I'm not sure about the other side, but both sides will get new transistors anyway.
Code:
NPN
2SD746A 220V 10A 200W Bmin=80 ft=15MHz
MJL4281A 350V 15A 230W Bmin=50 ft=35MHz
PNP
2SB706A 220V 10A 200W Bmin=80 ft=14MHz
MJL4302A 350V 15A 230W Bmin=50 ft=35MHz
