drspiff
Fisher "T" Aficionado
I'm putting together an integrated preamp/amp using the boards from Rod Elliot. Specifically P03A 60 watt amplifier and P88 preamp. When it comes time to put the selector switch in, I'm torn between using a double pole switch and 4pole switch. The question is whether to wire all the signal grounds together and use the double pole switch or to have separate switch lugs for the signal grounds.
Here are a couple of sketches of what I have in mind. This is using a double pole switch:
This is using a 4 pole switch:
The advantage to using the 4pole switch is any noise from the unselected inputs is stopped at the switch. Is this a worthwhile consideration? Or am I just straining at gnats?
