Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Please note that there are a few updates and clarifications made in the Audiokarma Rules, mostly relating to advertising and the addition of the new "Paying it Forward" & "Giving back" forums in the AudioKarma Audio Marketplace section.
They are located just to the left of the main rectifier diodes, 2 - 100mfd @ 50V and 2 - 100mfd @ 63V. These I would suspect if you get a steady hum unaffected by any controls. I did have a CR-620 pass through here where the problem was on the tone control board - can't recall which cap but the hum was affected by the Bass control.
and it also relates to the FM muting button. When depressed, the bass control causes hum - when not it does not.
I don't remember it being this way prior to replacing the 100uf caps in the PS - i only replaced the ones with the lower voltage rating - couldn't get the bigger ones - maybe tomorrow i can though.
yes. the caps i replaced are the right value and orientated correctly.
The hum existed prior to changing the caps - i just don't remember if I tried switching the FM muting button or not.
Have you checked for cracked or cold solder joints? Use a magnifying lens to examine each joint. Remove the solder from any joint that is questionable and resolder it with some new solder.
if I don't allow power to the whole tuner board - there is no hum at all...
i haven't replaced the 1000uf 50v cap and I think it might be that.
(i do get a big speaker pop now when i power it up... not sure what's going on there)
