Vulture
Broad-Spectrum Hobbyist
After five months of slowly buying parts and project holds,I finally finished recapping the first crossover! Because of the huge disparity in capacitor size between old and new, I ended up relocating the inductor off the back of the terminal cup where every else is. I now have 6-8 inches of solid copper bell wire as lead extensions. The plan is to use velcro to attach it to the interior floor of the cabinet.
Because of the oddball values on the original capacitors; 32uF and 6uF, I ended up mix-n-matching Erse PulseX caps to match. I have a 27uF and two 2.5uF all wired parallel to make the 32uF, and a 3.3uF and a 2.7uF parallel to make the 6uF.
So far, I have two questions:
1) Would twisting the extension leads for the inductor cause interference of any type? It would certainly look better, but that isn't worth causing signal problems.
2) Have I messed with the XO mojo by using so many caps? I'm most worried about the three wired in parallel. I know the smaller ones will charge faster than the 27uF, but will that cause a significant and problematic change to the sound?
Also, I would like to enter a self-nomination in the category of "Worse Solder Job of 2012". :stupid: First time I've dragged that iron out in at least eight years!
