Un huh,,,yessir,,,^^^^ this ^^^^ x2...I could not go by brand, as most have done good ones and a lot not so good ones IMO.
I like...
TDA1541
PCM1704
PCM1702
PCM56
PCM63
If the Luxman was the LUXMAN DA06, it was very well reviewed by stereophile, and uses the Burr-Brown PCM1792 DAC chip.AK, Burr Brown, Cirrus, or ESS?
Only have a couple I use with USB. A Teac Burr Brown and a SMSL with AK. Personally prefer Burr Brown thru the same amp chain.
Was looking at some Luxman DACs tonight that use BB. Wonder why?
Burr-Brown made the AD1865 chip, in a lot of peoples views the best dac chip ever.
Of course you are correct Always difficult keeping up with companies changing, even worse looking at vacuum tubes these days, one company bought out most names in the beginning of this century[Cough cough]....Analog Devices. Burr-Brown was bought by Texas Instruments some time back, which might be where the confusion came from, but I believe Analog Devices is still an independent company.
I've heard the PCM1704 implemented well in several TOTL Denon machines and always loved that sound.
I like...
TDA1541
PCM1704
PCM1702
PCM56
PCM63
All good here, MattHaven't heard the last 4 though the best I've heard/owned is the Philips TDA1541A S1 in my Muji Studio DAC II. OPAMP rolling really made this DAC though (2x LM4562NA + 2x Burson V6 Vivid). Still running the stock NOS Philips ECC88 tubes and haven't touched the caps in the signal path yet.
The best modern DAC I've heard is the AK4497EQ though it doesn't really compete with the old TDA1541....
Lol... You know I only paid attention to who I was quoting before clicking on submit. How's things Ian
New Sensor Corp?
Unless the models in question use identical power supplies and analog output stages, you are really not comparing the DAC chip(s) themselves.AK, Burr Brown, Cirrus, or ESS?
Understood. Which is exactly what I did with a Music Hall DAC 25.3. Such was facilitated by the original op amps being socket mounted. Not so much for many like the Teac and the minions of low priced Chinese sourced DACs as those are wave soldered to the board. It also uses a low noise R-core tranny in the power supply.The op-amp thing is no biggie IMO,just roll in some Burson -or- Sparkos discretes and you've basically got that deal covered.
The power supply situation is another story,it often is what it is.
Implementation implementation implementation. It doesn't matter what chip is used, it depends on how the whole DAC is designed.
I am using a TEAC UD-501 DAC, which has two Burr-Brown PCM 1975 32-bit chipsets (1 for each channel). Based on your list it should be inferior but MANY reviewers use this DAC as a standard to test others by. WHY? How the whole DAC is designed and built.
That’s a weird thread-starting question.
It’s like asking what’s the best engine in a sports car.
