Many like the ElectroHarmonix 6CA7 matched pairs.
Biasing is done to the line on the meter on each tube from the pots on top of the chassis powered up after warmup. I recommend downloading the owner manual.
NEVER EVER CHECK BIAS WITH THE AMP PLAYING, EVER!! You risk ruining the totally unobtanium meter.
Yes, there are components associated with the bias pots that can be checked. Is it high or low on the bias?Roger that. I am able to adjust 3 of the bias pots but the 4th doesn't move the needle on the meter. Is there a component I can check under the hood?
Which tube position?The needle works fine on 3 of the tubes but doesn't move on one of the tubes, stays on the far left position. I switched tubes in that position and the needle still is motionless. What components do I want to check?
We may start with pulling the output tubes and carefully checking the socket voltages to chassis of the nonbiasing tube position against another position. We are primarily interested in tube pin positions 3, 4, and 5. They are numbered clockwise from the bottom, starting at the index notch, counterclockwise from topside. Pins positions 3 and 4 may be at potentially dangerous high voltage levels near 500 VDC, so exercise extreme caution.
Is this from bottom with tubes installed?It's B2...pin 3 438vdc,pin 4 312vdc,pin 5 -38.25
I assume B1 would be the same channel, pin 3 444 pin 4 445 pin 5 -40If so, a provisional fix may be to set bias at problem socket by matching pin 3 voltage with opposite tube in that channel.
Inconvenient, yes.
Inspect switch to see if there is a problem with contacts in that test position to meter.
I'll replace that resistor tomorrow. Do you think that it would resolve both the bias dial issue and the lower screen voltage than B1? You're the 2nd person to mention Winged C tubes this week...are they really audibly that much better than a $30 EH quartet?Check the 100 ohm screen resistor on that particular tube socket. Often these open or change value and you won't be able to bias that output tube. Replace with same type (Carbon) and 1/2 watt rating. 5% tolerance is better.
As for new tube recommendations, the SED/Winged "C" (now NOS) are excellent. The New Sensor Svetlanas are not too shabby either, and cheap. I recently acquired another 8B and it had these installed. Sounds great to me..
I always use 1/2 watt, but Pio1980 is right that a 1/4 watt will provide more protection. I do always find the 100 ohm 1/2 watt screen resistors toasty or overheated on Marantz tube amps.
In regards to the SED's, I just happen to use them during their heyday and liked the sound. I also used the Gold Lion KT77 reissue, and liked it, although they were a tad dark, more of a 6L6GC beam tetrode sound.
I am curious about the EH's myself. I may try a quad sometime soon!
