linuxslate
Well-Known Member
I have decided to take the concepts from my Sub-miniature Tube amp project, and apply them to a larger build.
This includes using all solid-state, switch mode power supplies for all of the needed voltages. Please see this thread for more about that.
This thread will document (and request comments/help) for this project.
Overall, I am building a very basic 6BQ5/EL84 Push-Pull design. Perhaps best thought of as a copy of a Packard-Bell console amp chassis. It could also be thought of as the same design of the Sub-miniature Tube amp build around miniature tubes.
A schematic will follow. When I post the schematic, I'm sure I'll get lots of comments suggestions (and I do have some questions), but we'll leave that until I get a little closer to actually soldering.
For now, just as a teaser, and to show that I am getting serious, here is a shot of some of the parts I have collected so far:
First, of course I have to mention what is not pictured:
-- Obviously the Chassis. That is on it's way.
-- The chassis is supposed to include an IEC chassis-side connector with integral fuse holder.
-- Resistors. I have lots of resistors, and I'll pick needed values at build time.
-- Capacitors other than the (shown ) main coupling caps. Again I'll pick needed values at build time.
-- I am currently planning on having a built-in USB DAC. That is also on it's way.
-- The amp is going to have another feature that I am not revealing at the moment. It depends on (yet even more) parts from China, and my evaluation of them when and if they arrive.
-- Misc common parts such as wire, grommets, tie-wraps, heat shrink, screws, etc.
I should also mention that due to the use of the power supply modules, there really aren't a lot of other parts.
Other comments:
-- Yes, I pained the OPT's. They are new, but not cosmetically perfect, so I am attempting to make them look cool. The shields were removed, painted, and black glitter was added.
-- The small buck converter with the green heat sink (left center) is the filament power supply. I may substitute a slightly larger one with a higher current rating (on hand).
-- I am even building my own power cord. The pictured fabric-covered line cord is cut from a 3 outlet power strip. The one shown is actually purple. I have another one in another color, and may even buy another if I see one with a cord I like.
-- Hey! Who left the clip from the bag of sockets in the picture! (That's not part of the amp.)
Next:
The tubes are not the ones I planned to buy. Story (and request for suggestions) to follow.
Other comments:
Next:
