Hi all, I'm going to be running some dedicated 20 amp lines in my listening room and was wondering if there's anything special I should know about.
Okay so I'm going to run 12 - 2 in 2 circuits, one for the amps and one for everything else. Now should I run them on separate legs of the panel? As for receptacles I got some Hubbell solid brass 20-amp as the hospital grade are all nickel-plated that I could find.
Good things all. I have an EE friend whom I can ask about calculating my main panel and my two subs. All the lights in the house are LED. Maybe I can set up a home theater / audio sub panel.Circuits interconnected by the audio system should ideally be fed from the same leg of the split phase power.
Also, ideally you have an electrician in the panel already, so it's a great time to ask him to strive for as equal of a balance of power as possible. Plus hope that you can get the more likely noise maker circuits to not be on the same leg as your audio system. Also he should while in the box check tightness on each and every lug connection. Very important!
When you first look at these desires remember it's more about actual typical load use than it is the breaker value. So he should be breaking out an amp clamp and you should run around for him turning a few things on and off. If something is not normally in use during the time that your are likely to be listening, then don't really attach to much importance to it.
I would consider fan motors for AC units and any lighting circuits with chopper style light dimmers as the highly undesirable. Cycling on and off higher loads next then.
Do yourself a huge favor and call a hazmat team in for any of those dangerous curly q bulbs, get those real gone. And try to buy real bulbs and avoid the modern expensive and noisy LED ones. All terrible noise makers, both radiated noise and back onto the electrical line.
Another thing for a check, tune an AM radio to a place in between stations and walk around getting it closer to things like always on devices and all wall wart supplies and see how many radiate extreme racket into the radio. Those that do should be replaced if possible.
Do the panel balancing effort and avoid shooting yourself in the foot with noise makers and you can have a nice solid footing for your audio system to stand on! I've measured with a distortion analyzer the AC distortion down around a 2 percent level for a larger sensative business doing these pretty easy to do things.
EV3
Any recommendations for those?Lastly, as a matter of personal preference, I am now very much a fan of local active noise reduction units at the outlets, the price has gotten quite reasonable for such small devices, they do not impede full current delivery in the least, and they work IMO.
You're fine with the Hubbell spec grade outlets. Hospital grade only adds a solvent proof material and a green dot.
The contacts inside Hubbell hospital grade (8200, 8300) are not nickel plated.
