I've been interested to see if it is possible to open up a NLA tweeter and replace the ferro-fluid,
the quick answer is that it does not seem to be practical. I have a pair that are badly burnt
from being over driven and these are the test subjects.
Step 1. Desolder the Lead in Wires
Step 2. Remove the Metal Grille
I did not think that this could be done in a non destructive way so I just started prying,
then I thought to apply a heat gun. This is a very powerful unit for stripping paint and I have
to advise not to use the high setting which burnt the red paper part but finally the grille is off.
Note that these were so badly overdriven that the lead in wires probably started to glow red
hot as you can see (green arrow on the right) a burn mark in the red paper. The rest
of the burn marks on the left and center dome are from the heat gun.
Step 3. Pry and Cut Under the Perimeter to Release the Red Paper, if the paper was not so
brittle one could look for a release chemical for the glue but rather this seems to be hopeless.
Issue 1. The issue that I see in removing the dome is that unlike most paper cones the red
paper is VERY brittle, note the cracked paper indicated by the lower green arrow and the cracks
all around the perimeter. I'd expect paper to tear not crack:
Issue 2. I've found in testing these that the fundamental resonance Fc is not at all consistent.
My initial guess was varying degrees of ferro-fluid decay but now I believe that it is the degree to which
the paper has hardened with age.
Here's a picture of the voice coil windings some on and other off the metal former, all are burnt to
the point of shorting:
Another view:
People, including myself, have reported cracked holes in the domes and I always wondered why it
happened. It seems that the paper has just become too brittle and I don't see any simple way to
restore these tweeters. One could sample and test enough of them to find a solid pair that are in spec
for situations where originality is required but otherwise a modern replacement is the best option IMO.
Another view:
