Alps Pinouts
I know that this is an old thread, but maybe this will help others who are looking for the Alps pinout assignments.
For 6 pin Alps (
without loudness pinouts)
Pin 1: (from right to left; looking at the pot at the back where the label is): Left Channel Ground
Pin 2: Right Channel Output
Pin 3: Right Channel Input
Pin 4: Right Channel Ground
Pin 5: Left Channel Output
Pin 6: Left Channel Input
(For those Alps models with loudness taps, then pot will have two extra pinouts (a #4, being the right channel loudness tap and a #8, being the left channel loudness tap).
In general, most pots will have one side (outside taps) being ground and the other outside taps being the input. The center taps are usually the outputs (wipers).
For those that are replacing the old, outdated volume pots on the Dynaco PAS series, keep in mind that the Alps has the inside (against the front panel ares facing out of the units/or another way of putting it is the taps immediately next to the threaded shaft portion) AS THE LEFT CHANNEL SECTION. Whereas the ORIGINAL Dynaco POT HAD THE RIGHT CHANNEL SECTION IN THIS LOCATION! Just something to keep in mind...
I am attaching a schematic (which I cannot take credit for, I can't remember where I lifted it from, but it was somewhere on the Web...If I could remember, I would post credit to its author...) which might help further.
Hope this helps...
