hopjohn
Silver Face
Frazier 7 (Seven)
These images are reference for the stacked piezo version of the Frazier model 7.
The model 7 consists of a 12 inch driver, two 4.5" mid range drivers, and two piezo tweeters.
Specifications can be found on this datasheet
The mid range drivers are sealed within a shoebox sized enclosure of their own. A 2"x 2" support beam runs through the center. The multi-section port runs vertically along the front right edge.
The 8 ohm 15 Watt L-pads read Culver Electronics Inc. Inglewood, CA
The woofer markings may date it to 1967.
Four 12uf 100V EAO brand caps are strapped together in parallel to create 48uf of capacitance.
The massive, doughnut sized coil is marked "30".
