Hey, all.
I've been in conversation with a member of AK ( and DIYaudio), Dcgillespie, because the two of us have the same primary listening rig: Heathkit W4-AM's into Klipsch Cornwall 1's. He revealed that he had done some modifications to his W4's that seemed quite impressive to me that i'm going to try for myself:
1) A modification that fixed the well-documented instability these amps have ( ringing ) by modification of the feedback loop and a few other small changes. This mod is not unlike the Bricktop mod that most people with Heathkit W4's are familiar with. His comments on it are as follows:
Bricktop's modification is certainly good, although he fundamentally changes the topology of the feedback system. His approach is to apply some local feedback around the output tubes, and reduce the global feedback around the amplifier to improve stability that way. It certainly works, and I am hardly trying to imply it is not a valid approach.
The problem I have with it, is that the OPT is what produces the most distortion in the amplifier at the frequency extremes, and reducing the feedback around that component only serves to reduce the ultimate performance that can be achieved. It also reduces speaker damping as well.
My approach leaves basically the original global feedback factor in place that Williamson specified, but applies it in such a way the the amplifier is very stable, and does not need the hang-on network to load the amplifier, when no actual load is in place. Such networks are notorious for reducing power and performance in the upper frequencies of most typical designs. Note if you will the will the final version specifications of the W4-AM, versus those of the original W-4. Granted, the final version was stable, but at a significant cost to performance. With the feedback and stability networks I devised, it achieved the performance of the original version, with the stability of the later edition.
2) An EL-34 in Triode mode conversion to the W4, allowing the unit to run in Class A. This schematic is forthcoming; I will add it as i get the notes and redraw it. (note that this modification prohibits use of the heathkit preamp that bundled with this amp, because the extra current capabilities of the PT are used on the EL-34's instead of the preamp tubes)
So, here is a link to the feedback loop-modified Heathkit W4-AM schematic. I've included all of the notes for what to modify in the lower right corner of the drawing, and all changes to the original schematic are done in red. Enjoy.
