HELP Sony STR-V4 No Sound Right Channel
Discussion in 'Solid State' started by CavScout, Mar 14, 2019.
  1. CavScout
    CavScout Well-Known Member
    638
    Medicine Hat
    I bought this receiver in great shape but no sound in the right channel.
    I checked the 2 fuses and put a lot of deoxit in the Vol,Bass,Treble, Balance and toggle switches with no result.
    Any suggestions ?
  2. CavScout
    638
    Medicine Hat
    I am wondering if it is a bad balance potentiometer.
    When I turn it ALL THE WAY to the right, I can still hear a little bit of sound on the left
  3. avionic
    47,831
    Fort Dodge, Iowa
    Try the headphones..
  4. CavScout
    638
    Medicine Hat
    Same result with headphones.
    I noticed when I have the balance pot cranked to the right I get distorted sound at 3/4 volume.
  5. avionic
    47,831
    Fort Dodge, Iowa
    Check your right channel emitter resistors out of circuit. Before I jump to conclusions about the balance pot. Need to verify that the right channel amplifier is working.
  6. CavScout
    638
    Medicine Hat
    I'll have to figure out what you are referring to somehow .
  7. avionic
    47,831
    Fort Dodge, Iowa
    Think you can find R725 and 726 They are .47Ω ceramic /cement wirewound 5 watt resistors.
  8. century tek
    century tek Super Member
    3,810
    The Evergreen State
    You prolly shouldn't be poking around then! :no:
  9. CavScout
    638
    Medicine Hat
    Tested them out of circuit and they appear fine ( .5 ohms )
  10. avionic
    47,831
    Fort Dodge, Iowa
    Reinstall those and check the two for the other amplifier.(right channel)
  11. avionic
    47,831
    Fort Dodge, Iowa
    These two are for the left channel.
  12. CavScout
    638
    Medicine Hat
    Yes, went ahead and checked those also. All good
  13. avionic
    47,831
    Fort Dodge, Iowa
    Great. Next,we need to check the power supply voltages powering the Rt channel.
  14. sax6
    sax6 Loudness always ON
    2,069
    Province de Québec
    Check preamp to power amp jumpers if any.
    edited...
    Sorry, checked out some pics and ... no jumpers ...
  15. avionic
    47,831
    Fort Dodge, Iowa
    +/- 45 vdc should be present on the output transistors collector. Center pin or metal " batwing "tabs.
  16. avionic
    47,831
    Fort Dodge, Iowa
    Does the bias adjust on the Rt channel?
  17. CavScout
    638
    Medicine Hat
    I got the following readings :
    Q713 - 44.5 VDC
    Q714 +44.5 VDC
    Q763 0.00 VDC
    Q764 - 44.5 VDC
  18. avionic
    47,831
    Fort Dodge, Iowa
    There is your problem..Should be +44.5 vdc
  19. CavScout
    638
    Medicine Hat
    So just replace with new transistor?
    Then what? Adjust bias ?
  20. avionic
    47,831
    Fort Dodge, Iowa
    Looks like it may be a broken wire or solder connection. Or..... burnt trace:rolleyes:
