This is a subject that I've often wondered about as it relates to many amps and the use of certain output tubes in lieu of 'original' tubes......such as using 6BQ5s for 7189s, or 6V6 for 7408, etc. The issue being that the rated voltage of the 'original' tube is higher than the available replacements. I believe there is a Russian sub for the 7408, but I'm pretty sure the the EL84M or 6P14P-EB is a good sub for the 7189. However, what if you just want to 'reduce' that B+ voltage to something more to your own liking.....for purposes of either matching an original spec.....or to not overload a tube.....or what ever? In my case, I just completed my first 'scratch' build.....and finally got the amp up and running. However, now in the 'tweaking' stage, and I'm noting that my B+ voltage is just enough above spec that it has me worried. Spec calls for 370, but I'm running at 405.
I placed a Current Inrush Limiter in series with one leg of the PT primary....and that dropped me to about 395....or about a 10 volt reduction. Plus, I got the added benefit of an increase in warm-up time. Not really sure if this is a benefit, as the delay in Secondary HV has got to be correspondingly delaying the filament side as well. So, while not B+ surge initially.....also no filament voltage. Since the inrush limiter is controlling the primary and thus equally affecting ALL the secondaries.....I'm of the opinion that any perceived favorable affect of any time delay from this device is negated by the equal delay in tube heater warm up time.
But, back to the point: Aside from utilizing the CIL device, I have also attempted use of a power resistor off the rectifier to the first stage of the PS filter.....which incidentally is also where the OPT and Screens are attached. I then have 2 more stages of filtering followed by a fourth and final stage where the driver voltage is taken from. So, any reduction at the front of the filters as seen by a resistor TO the first stage of the filter would have to be compensated for at the fourth stage.....or so I figure. I've been advised NOT to use the power resistor at this stage....and to just feed the rectifier directly to the first stage. This way I'm not restricting voltage to the filter caps or the power output stage of the amplifier.....and the amp will sound better! I'd love to hear some opinions about that.
Just for the record....with 150 ohms of resistance (using a 7 watt power resistor) I had a B+ of about 375.....damn near right on the money! But, again, I was advised against doing this.....so I pulled it and now have the current inrush limiter in line. I'm wondering....without attempting to build a regulator stage more complicated than the amp itself.....any other ways to do this......or comments about which way is better?.....or doing 'both'??
Many thanks, Tom D.
Many thanks, Tom D.
