Yeah, I'm hoping these hk's will be fine. 4 ohm mono has me a little concerned.
U should be concerned, 4 ohm nominal load that dips lower into a bridged amp is like the amp seeing 2 ohm, and even possibly 1.5-1 depending on how bad the dip. This is enough to blow your HK amp within minutes, those small heatsinks are not enough!
A lot of power amps even In the pro audio scene that are rated for 4 ohm bridged don't account for dips and prolonged usage.
Not to mention of its a passive design your almost always going to be thermally limited
Only really well designed high current amps can deal with 1 ohm dips, mark Levinson, pass labs, krell come to mind. Very expensive to build because of heatsinks, and massive power supplies
Best bet is to horizontal or vertical biamp. Vertical may be the best bet if the speakers require large current for the woofers, since the power is spread between both amps
Horizontal- HF l/r on one amp, LF l/r on one amp
Verical- L HF L LF on one amp, R HF R LF on one amp
Both situations amp is in stereo mode
