Mellotronix
Super Member
Just curious about this. I bought one of these Prime Scouts in Spring of 2019. Almost immediately, I noticed that it generated extreme amounts of ESD (static electricity) which I documented here on AK. I damaged three phono preamps in the space of a month while trying to sort out the issue. Two of them, a Project Tube Box DS and a Sutherland KC Vibe were fixed under warranty. I blamed it on the low humidity and extreme electrical anomalies that occur at high altitude.
I installed industrial grade rubber floor mats that are grounded, and I ran a ground wire from the main bearing assembly of the VPI to the ground plug on the terminal. Then I blew a component on my Sutherland for a second time. Then a third time while using an anti static gun. I was totally miffed, but Sutherland was amazing. They kept fixing it and paying for shipping. People on this forum thought I was crazy (seriously, I got PM's that you wouldn't believe).
Now I see that VPI has apparently added a ground wire from what appears to be the tonearm base to the grounding terminal. I'm thinking that the good folks at Sutherland may have had a conversation about the repairs that they were having to do for VPI owners. Perhaps other VPI's suffer from this as well.
When I grounded the main bearing assembly, I assumed the the tonearm would also be grounded because there is a steel bottom plate that all of the components come into contact with. Now I'm questioning my reasoning. Are there nylon washer involved in some of the parts?
Anyway, I think that the current product photos for the Prime Scout have answered my question.
