Edit: Attached an actual sized layout drawing in .pdf format, see instructions for use in the last
paragraph of this post.
I looked back in my notes and noticed that while I owned 2 pairs of Minimus 7s since
the 1990s and kept them stock, I first began measuring them for mods around August
of 2008, that was a long time ago! lol. I worked out the PB-1 mod through measurements
around that time and offered it to Zilch in December of 2008. A few adjustments became the
PZ-2.1 mod. Link to the original thread, PZ-2.1 is finalized around page 7 on that thread:
http://audiokarma.org/forums/index.php?threads/minimus-7-loudspeakers-measurements.199790/
Several people have asked if there is a PC board available for the PZ-2.1 mod for the Minimus7
and I have done a layout as shown below. I used 5W resistors and there was no 40 ohm so I substituted
a 47 ohm resistor and thus renamed it PZ-2.2 to avoid confusion. I also added the option for a tweeter
level control. I do not expect there to be any sonic change due to the resistor difference. I am of the
opinion that the design is so simple that it can be done on proto board, thin masonite, or even terminal
strips. If you aren't able to make a circuit board, then go ahead and build it with terminal strips.
Here is the layout on a 4"X3" board, done in Express PCB but not for production, just to have a
clean layout. Note that the components are placed closer to the top to provide room behind the woofer
so that a deeper woofer can be used as a possible future upgrade. I have added a tweeter level control,
since I see many different opinions on the best level for the tweeter.
Notes:
1. R2 is increased from 2 ohms to 15 ohms and the 25 ohm tweeter level pot is wired across R2.
Those who do not want to include the level pot should simply use a 2 ohm resistor leaving out the holes
for the wires to the level pot.
2. This view of the board is the copper side so we are looking through the board at the components. The
level pot is as it would be seen looking into the speaker enclosure to wire it up.
3. Two locations are provided for L1 the larger one to the left is the 18 gauge iron core from Parts Express,
the smaller steel rod type is mounted on board that I bought surplus. Only one location is populated depending
on which coil is used. The PE inductor should be hot glued down.
4. Note that the connection between R1 and C1 is in the air as can be seen in the picture with a twist.
The layout tool has no way to show this. The other lead of R1 reaches over to the IN- strip down the
middle also as shown in the picture. These are the only leads that do not go through holes close to the
component.
This board is not designed for a printed circuit board shop, rather I cut the copper away on a table saw
as described in this thread at DIYaudio. I also mention there mounting components to the copper side
so that through holes do not have to be drilled, these components are heavy and therefore through holes
are used in this design. This board could easily be fixed up for a PC shop to fabricate:
http://www.diyaudio.com/forums/cons...ype-pc-boards-etch-table-saw.html#post4910039
Here is the board after cutting on the table saw:
Here it is after tinning with solder, this step is not really needed but the solder does not tarnish as much
as copper and it just keeps it looking a bit better:
This board also completely replaces the old plastic cover for the input terminals and provides nice binding
posts on standard .75" centers. Note that one of the posts on the back of the box sticks up about .1" higher
than the mounting point for the XO board. There are two ways around this, double up on the gasket between
the XO opening and the PC board or cut the post down with a Dremel cutoff disk. I used the thicker gasket.
I used plastic type 5-way binding posts left over from another project with the mounting screws working
perfectly with the board. The posts in the parts list must be removed from the mounting board which is
not needed.
Component side view of the completed board:
Notes:
1. important THE METAL NEAR THE SCREW HOLES MUST BE REMOVED WITH A LARGE
DRILL BIT TO BEVEL THE EDGE, to avoid shorts to the screws.
2. All resistors should be mounted elevated as shown in the lower picture, forgot to do it at first,
but resoldered all the resistors after bending the leads as shown.
3. The above picture was made prior to the final layout above, it is 2.5" wide whereas the final layout is
3" wide. The wider board provides room for a new and larger tweeter inductor if you must use one, in
the event one doesn't have the original inductor.
4. I used parts that I had on hand, the Dayton 2 uF cap is longer than the one shown, also I used a 10W
for the 15 R only because I had it on hand, 5W is specified.
5. Hot glue the heavy components down, both inductors and the large cap. E-6000 craft glue, or even Shoe
Goo can be used instead of hot glue.
6. Double stick, foam, mounting tape is used to make a gasket around the binding posts, and it should be 2
layers deep because of the tall post on the back of the enclosure as shown below:
Two layers of foam tape is needed around the binding posts, then one layer up the center
and a second layer to avoid vibration against the top two posts:
Rear view showing tweeter level pot, and new binding posts:
Here is the PZ-2.2 schematic, note a few minor component value change of R3 = 47 ohms:
2020 EDIT: Stuart's L-pad version is better than how I did the tweeter level control so this is
what people should build for the version with a tweeter level control:
Minimus 7 PZ-2.2 Mod DIY Circuit Board by Pete Basel
Use the long shaft version of the 15W L-pad as I show here to provide clearance for the XO
board so that you don't have to cut the board:
https://audiokarma.org/forums/index...ard-by-pete-basel.750334/page-4#post-12561307
Parts list for the version with a tweeter level control, R2 is 15 ohms, note the use of a surplus woofer inductor.
The level pot is 25 ohm 5W from Radio Shack #271-0625:
Parts list for the version without a level control, the only difference is R2 being 2 ohms, note the use of a
surplus woofer inductor:
Copper PC Board 4" X 6" Single Sided board from Parts Express #055-134 can be cut in half to
make two 4" X 3" boards.
Edit: Attached an actual sized layout drawing in .pdf format. Print it out, be sure to check actual size
and tape it to the PC board to punch points indicating where to drill. Site along the edge and mark with a
wide Sharpie where to cut copper on the table saw if you plan to use this method. Align the sharpie mark
on the table saw for cuts by eye - this is how I do it.
Merry Christmas, and Happy Holidays, all the best for the new year!
Notes:
component.
not needed.
Notes:
