I wanted to hook up a single pair of speakers to two separate amps (a surround-sound AVR for gaming and movies but a stereo amp for serious music listening), so I looked into the options available. Turns out there's not much out there with banana plugs, and the available options are way overpriced.
This box can be used for my intended purpose, or it could be used in reverse to hook two pairs of speakers to a single amp (for A/B comparisons).
I had my dad cut and measure for the wood parts, and I did the wiring. This project cost very little to put together.
The banana plug input pairs on the back were bough on eBay for $8.34 total.
Ins and Outs are labeled. I had to add a tiny bit of shrink insulation to each input so they won't all short out on the metal plate.
Switches both to the left means amp #1 is active; both switches to the right means amp #2 is active. Each DPDT switch cost less than $4 at RadioShack.
Under each little leather pad cut from scrap is a screw for easy maintenance.
I added some drops of solder to reduce the chance of the bolts on the back of the posts from coming loose.
I challenged my dad to include a plexiglas viewing window on the bottom. Not only does it look cool, but it lets me check for visible shorts that could develop.
