Working and playing music!
For those just tuning in, I am describing a basic PC speaker amplifier that I made from the remains of a Sony CT-200 RtoR tape recorder. It uses the 30M-P23/30A5 tubes that are the topic of this thread.
My daughter picked "Ice Queen" by Within Temptation for the first test with actual music.
Both channels play sound, and seem within balance, although for this first test, my speaker placement was not ideal. For testing it was connected to my Vintage Sony 3", 2 Way bookshelf speakers.
It does have a ear-to-speaker level hum, probably straight 60hz, but it is not noticeable with music playing. It gets worse if I put my hand near the input terminals. It was also sitting right under my bench magnifier light, which is fluorescent.
The power transformer shell and internal return -- to AC ground voltage that I saw previously, is now gone. It was either from having no load, or just a test issue.
Interestingly, one VU (level) meter is not working, but it is the channel that was not associated with the wiring error mentioned previously. Troubleshooting tomorrow.
It has plenty of power for a PC speaker amp. Definitely will go louder than my last project, the sub-mini tube amp, before beginning to distort - at least to my ability to detect.
Initial input was from my mobile phone, and I also connected it to my PC. There was no evidence of a ground loop when connected to the PC.
Right now, my home-designed power Supply is pretty close to the intended voltages, and there is no evidence of anything getting hot. The bridge rectifier seemed to be
slightly warm when checked a few minutes after shut-down (having run for at least 1/2 hour.)
Here is a screen shot from PSU Designer of the power supply as currently implemented:
Don't get too hung up on the exact parts/values. They didn't have "That salvaged bridge rectifier at the back of your bench" as one of the choices.
With these values, the plate and screen voltages are a little "conservative." (Read as "Almost 20 volts too low"). Upping the voltage a bit may give me a tiny bit more room before the onset of the distortion, but the smart money is probably on "leave it as is."
A few notes on the pictures below:
-- Please understand that it will be fully or mostly enclosed. These do not show the intended end-state. I will make a Lexan top that will fit the stand-off over the PC board. The higher area of the back will be enclosed in the garbage can metal mesh. I plan to add some copper tubing for a slight "Steam Punk" look.
-- The loose purple wires are 6.3VAC. These will be used to run some LEDs. (But
not under the tubes! I
hate that. OK, perhaps "hate" is not appropriate in our politically correct world -- I have a personal preference against LEDs under tubes.) I'm going to try to arrange them to make some sort of cool effect with the Lexan.
-- I'll either mount the VU meters, or replace them with LED meter bars.
-- Note that the AC line cord grommet/strain relief used to be one of the tape motor vibration isolators.
I'll upload more picts when the project progresses.
